It's been four years since I posted anything about our old Yerf Dog 3200.
In the last day or two I resumed work on it. This thread is to catch up.
I left off with these two threads:
Handling issues:
http://www.diygokarts.com/vb/showthread.php?t=18272
Engine swap:
http://www.diygokarts.com/vb/showthread.php?t=18586
First, to catch up:
- The Predator motor swap that was done 4 years ago worked really well in some ways but there were a couple of glitches. What went well was the motor itself. We've used the cart 2 or 3 times in 4 years and each time the motor started on the first or second pull, and with the same tank of stale gas. We always have run the carb dry and drained the bowl when putting it away, and run E-10 gas with some 2-stroke oil added.
- What was not so good was rapid belt wear. I finally realized that the center-to-center distance was a little too loose. Not much, just enough. I had to dismount the motor and elongate the motor mounting plate holes on the cart. That gave us what we needed to get the belt set correctly. I have no idea why it was necessary to do this. Maybe a Predator factory manufacturing tolerance?
- I never got around to correcting the Ackerman or accurately setting toe-in. The cart just saw hardly any use at all. As a result, even though handling was better from when we started, the left front tire saw extreme scrubbing wear in, basically, a few miles of use. Not good.
- One annoying problem is that the turning radius turning one direction is less than turning the other. As a result we could not make a U-turn on our street if turning to the right. You could only do it turning to the left, and of course that is not the intuitive way to make a U-turn.
I'd say that the cart has seen an hour total of use in the past four years. After talking it over with my son we decided that we are past it and I decided to spruce up the cart to prepare it for sale.
In this post I will document the work I am doing to dial everything in so that it can go to a new owner with a clear conscience.
Handling issues:
Engine swap:
First, to catch up:
