What is a Governor on an engine?
jr dragster T
Cold place
Because there is still a posability and it has happened to people before but most of the time it was operator error. I just dont want to come forward and say "It WONT happen" Then somone gets hurt. Its not worth the risk. It depends which way you look at it. If you value your life and there is any shadow of a dought you may have issues with your flywheel DONT take the chance!
brendonv
Australia, Perth
clones and briggs on youtube said in one of his vids his mate over revved the engine on his kart and the flywheel exploded, luckly he wasnt badly hurt but a bit of the fin hit his eyebrow and he needed stitches, hes a lucky guy.
Affair_driven
BULL DETECTOR
Wolf Point, Montana
Bull.
Show me!!!
jr dragster T
Cold place
Yeah I agree lets see a link. On the internet words are only words untill you have more backround proof. Everyone has there opinion on this flywheel issue.
GXMATT
Mini Kart Guy
uk
Yeah i will believe it when i see it. Are you a health and safety officer or something? Its like saying "if you drive a car there is a chance you could have a horrible accident" it happens. There is always a risk in driving go karts. Not so long ago i hit a small stump and ended up in hospital with a cracked rib and some cuts. Accidents happen, if your over cautious leave your governor on and drive around slowly. If your into your speed and dont mind a calculated risk de govern it and enjoy yourself.
GXMATT
Mini Kart Guy
uk
im suprised you even own a go kart.
brendonv
Australia, Perth
Shut up dude, im just saying, it can happen. If ur aware of what can happen then u will watch ur rpms so they dont get to high and this will never happen. It is uber rare for a flywheel to explode, a rod will probably go b4 the flywheel does but its just a thing that could happen. Hey, if u dont rev it to the extremes u will be fine.
Kaptain Krunch
Pro Junk Collector
vermont
I think everyone who runs a de-governed engine should just run a thick steel shroud around there flywheel so everyone stops arguing, then its safe and fast.
theo
When I'm driving in the ruff, I'm more worried about getting jilpocked by a stick then my flywheel blowing up.
theo
GXMATT
Mini Kart Guy
uk
As far as I'm concerned, exploding flywheels on a stock ungoverned engine is pure myth/hear say.
I'm not worried at all.
No scatter shields for me.
same here, a tree could fall whilst im driving so maybe a reinforced steel cage to protect me?
GXMATT
Mini Kart Guy
uk
still no video right?
Affair_driven
BULL DETECTOR
Wolf Point, Montana
If one did exist, someone on this forum would have found it by now or, at the very least, found something to backup what has been stated.
I have found nothing on-line about this other than the usual "it happens".
Airplanes crash, but that has not stopped me from flying.
Probably have a better chance of getting eaten by a crocodile named 'Elvis' than to be hurt or killed by an exploding flywheel.
GXMATT
Mini Kart Guy
uk
Exactly. Its a VERY small risk shadowed by the risk of actually driving a go kart. Un governed engines are as safer then actually driving a go kart. so if your that worried about your flywheel exploding maybe golf is for you.
eesakiwi
Most of the replys here don't have many true facts.
BrendonV's first post & thats about it.
Governers are normally used on stationary motors.
They keep the engine going while under differing loads without stalling.
ie, the lawnmower, differing loads.
an example would be if you put a stationary motor on a concrete mixer or a power generator.
The governer is a small spinning thing with a spring & some pivitable arms with weights on them.
Its connected to the carby.
As the loadcomes onto the motor the engine drops in revs.
If there wasn't a governer the engine would stall.
But with a governer the little spinny bit slows down & at the same time the weights don't have the cenrafugal force on them & so they then move inward against the pressure of the spring.
The spring pushes a central rod up thats connected to the carby, the carby then opens & theres more air/fuel & the engine then climbs in revs.
So it don't stall.
On the other hand, the load is taken off the engine.
Normally the engines revs would increase.
But the spinny thing increases in revs & the weights push out, pulling against the spring.
It then closes the carby so it don't get as much air/fuel & the revs drop back down.
On a Gokart?
Well its not needed, depending on the way you connected up your throttle cable it could be bypassing the governer, or the govener has been completly disconnected from the carby & the cable opens the carby now.
Stationary engines, with the stock carby, will not rev so high that they will explode. Governer or no governer..
