truck talk
Bluethunder3320
the bolts crumbled to nothing so i cant even get a socket on them
EDIT: ohh maybe i can just crumble them apart and it will come off!
Bluethunder3320
ill try tomorrow just chiseling at them... see what happens.
its difficult because every time i hit it with a hammer, rust would pour down and cover me coming from all under the truck LOL
EDIT: ill be buying a gallon of POR15 to finish the job the PO started. the whole underneath will be coated.
fowler
Bullsbrook West Aus
try cutting bolts off a dozer
the only way u can cut them is by cutting from above u
everytime i press the oxygene i get hot metal rain
use a face sheild to stop the rust getting in your face
u should at least be wearing saftey glasses
Rustydog2010
NZ Nutta :|
New Zealand
Ah yes, cutting off belly pan bolts on a D10 bulldozer. Good fun. :ack2:
Bluethunder3320
I reckon they are build the nuts to rust weld themselves to the bolt making one peice :mad2:
:roflol:
haha yeah they do.. i coudnt get any of the bolts off so maybe this weekend if i have time ill remove the good gas tank, fill the bad gas tank with water, and cut the mounts off with an angle grinder and anything else while im at it.
i probably wont replace the tank, im good with one gas tank. dont need dual tanks. id rather spend the money on parts i need.
B.M.800
TheBeal.
Central PA
^^ Is there holes in the tank or something? I wouldnt think it would need to have water in it... unless its full of holes...
crazzywolfie
Orangeville, Ontario
which tank is the good tank? i know on my dads ford the front tank is larger than the rear tank. i think if you do remove one of the tanks you might have to change where the return line goes. i think the return line runs to the opposite tank of the one you are using.
matman55
I dont have a camera!!
Mims FL
Blue, I think this is the truck for you ;)
In the UK we take a theory and practical test after we are 17, then you can do whatever.
Screw trucks, get one of these
have you seen the vid of this kind of car jacked up and had a "roll cage" put on it?
Bluethunder3320
it smells like 15 year old gas and its weeping underneath. i think it could catch fire lol
the front tank is the good one. maybe ill find a way to just put the return into the front tank.. its bad if there is gas returning into the leaky tank
B.M.800
TheBeal.
Central PA
Your call...
My dad has talked about people welding/cutting on a tank FULL of fuel... long as no spark can get to the fuel, the heat shouldnt light it ether... There needs to be a certain ration of fuel to air for it to ignite.
Better safe than sorry though. No sense in trying to be the human torch...
:D
Bluethunder3320
Your call...
:D
i dont know about you but i really dont want to grind on a gas tank with 25 gallons of fuel in it.. lol
im bringing the truck into school monday! finally. but we have to bring a big cabinet down town today and the suspension isnt fixed yet...
theres only one leaf on the right side and 2 on the left side... its gonna be sagging pretty low haha i just hope it doesnt break
and when u hit a bump at 50 mph the back of the truck almost catches air lol
fowler
Bullsbrook West Aus
How the hell did this thing pass licenceing tests
Oh well at least u can get it sorted now
If the tank is junk then fill it with water
If u have to grind the good tank then fill it with deisel
It is surprisingly hard to set deisel on fire
or the welders at work weld big tanks all the time
If they really have to they fill it with inert gas
CO2 or argon
crazzywolfie
for some reason them dumb fords seem to like breaking springs. my dads ford had the exact same problem. 2 broken leafs on 1 side and 1 on the other. his also had a coil spring break not far from the top that we had to fix. when you replace your old leaf springs you should keep all the good leafs off the old ones. if you feel up to it you could cut the ends off the old main leafs and stick it under the new main leaf as kind of farm grade add a leaf kit. my 81 dodge ram 150 has an extra 2 leafs on each side and the rear end sits higher even when it is loaded full of stuff.
