Torsk (Backbone Chassis) Kart
Now that part of the steering is pretty much complete, next is to work on the spindles
When I capped off the ends of the front axle, I angled the plates, where the spindle mounts to ~10*
(I read somewhere, that's how it's supposed to be)
...but, it didn't look right
So, I did some research
(back to the books, so to speak)
http://www.diygokarts.com/vb/showthread.php?t=11760&highlight=caster+camber
So, to set it up right, you have to keep in mind
...Caster (the angle of the spindle, when viewed from the side)
...Camber (the angle of the spindle, when viewed from the front)
...Toe Out (the angle of the spindle, when viewed from the top)
...& King Pin Inclination (an imaginary line thru the spindle main bolt (king pin) to the center of the tires contact patch)
But, it seems that there are no definitive answer
...there are a lot of variables
...& it depends on the specific situation (how the kart is designed & what you intend to do with it)
So, for this kart, I am going to
...set the Caster @~7-8* (10* just seemed like too much)
...redo the Camber, back to 0* (leaning front wheels just don't look right)
...& set it to Toe In just a bit (it's easily adjustable later)
Also, I am using factory made spindles so, there is isn't a lot I can do about the KPI (without extensive work)
Moving on (now, with more info)
I drilled 1/8" "pin/screw" holes in the center if both front axle end plates
Lined the spindle brackets (up/even) with the bottom of the axle tube
...& drilled corresponding "pin/screw" holes
This way I could "screw" them on (evenly on both sides)
...to more accurately place & adjust them
I can lean them "outward" to "fix" the Camber issue (that I caused)
It also allows me to "very accurately & evenly" adjust the Caster on both sides (to matching specs) :thumbsup:
After double checking the Caster & Camber
...I welded 'em on good :thumbsup:
Next, is to make some tie-rods
Used a piece of 1/4" x 1" steel as a straight edge
...layed it across/behind the spindle brackets
...to help align the spindles
Measured, marked & cut a couple of pieces of 5/16" rod
(ya, I know it's kinda small but, it's hard to do light weigh & heavy duty at the same time)
(we'll see how they do, can always add beefier/heavier ones later) :cheers2:
Threaded both ends ~3/4"
...added the center links & ends
...then toed 'em in just a bit :2guns:
I got a little more done on the kart :thumbsup:
Back to the seat, kinda
Gotta be able to mount it, before we put the cover on it
So, for the seat bottom, I just drilled (2) holes into the backbone & also, added corresponding T-nuts
For mounting the seat back, I added a couple pieces of 1/8" x 1" "cross bars", with 1/4" mounting holes & added corresponding T-nuts, in the back panel of the seat
I used my "new" spot weld mounting method
...drilled 1/4" holes in the ends of each cross bar
...clamped 'em on & filled in the holes
But, just for Ha ha's I banged the back of the top bar
...just with my hand & (1) side just "poped" off :ack2:
Well, :censored:
"Back to the drawin' board"
...clamped 'er "back in place" & welded 'er on the "old fashioned way" :thumbsup:
It takes a lot of heat input, real fast, to do a good plug weld.
Important detail :thumbsup:
Now, ya tell me :cheers2:
Thanks, now we "all" have more info on the what & why :cheers2:
I'll still use it for just "tackin'" stuff in place
...but, then apply a "good" perimeter weld :2guns:
Speakin' of :idea2:
...remember, I just "spot" welded the steering housing foot (as a test)
Abort Test...Abort test
...not waitin' for it to "fail"
So, I went back & added some extra welds to the steering housing "foot" :thumbsup:
Had to separate the steering & nylon bushing, again
...welded (1) side
...checked temp
...waited (for it to kool a bit)
...then, welded the other side
Not quite as clean & pretty
but,
Yup, that should do, better :2guns:
Been lookin' into options for front wheels
I would like to use those 13 x 5.00/6 ribbed tires that I have on the front
...but, they need narrower rims (like ~3" wide)
I checked with BMI karts & a few other kart part places
...but, all I found (in 6") was the wider rims (like ~5' wide)
Lookin' in the Surplus Center catalog
...I found some narrower 4.10/3.50-6 rims/tires (hub width 3 1/4") #1-3657 for $12.95 ea.
...But, not sure about them bearings (kinda remind me of HF wheels)
Anyone know of "higher quality" bearings for these type of wheels?
I also found some (kinda outta the ordinary) 6" wheels that caught my eye #1-116259
...they have a 3" wide plastic rim with ceramic bushings
(for use around corrosive materials like salt & fertilizer)
...a 4.00-6 ribbed (wheelbarrow) tire
...& are super light weight
I'll give 'em a try, if they don't work out I can just use 'em on the 2-wheel dolly
(as long as I don't bust 'em during testing)
First pic is of 6" plastic wheel (left), 6" steel wheel (mid) & the 13-5.00/6 tire (right)
Second pic is the 1-3657 steel wheel
Third pic is a close up of the bearing
Fourth pic is of the plastic wheel & bushing
Fifth pic is a side by side of the plastic wheel & the 13-5.00/6 tire
Six & seven are of the kart with the steel rim
Eight, nine & ten are of the kart with the plastic wheel :cheers2:
anickode
S.E. Michigan
Order floater wheel bearings from a go kart supplier. They're like 4 bucks apiece. Same 1⅝" OD as hand truck bearings. Just press them in and go. That's what I ended up doing on my budget kart with some good quality one piece 6" hand truck wheels. Just a bearing upgrade. When the tires give out, I'll buy some better ones.
We have had a lot of rain & humidity lately
...& we're beginnin' to get some corrosion (rust)
I think we have most of the major "frame" stuff done
So, I guess it's time to get 'er cleaned up
...& then, sealed up :thumbsup:
After several hours of deburring, smoothing, rounding, filing & sanding
When I thought I just about had 'er done, I noticed
...that we got no floorboards or stirrups (so to speak)
This frame is designed for the operator to "prop" their feet right on the front axle housing
...but, for "safety" purposes, I think it would be best to have something down under the feet too
...just in case :thumbsup:
I got some 8' running boards off of a Ford F250 p/u
...they should do the trick :thumbsup:
JK :lolgoku:
We don't need nothin that elaborate
...just small plates under each foot
I found a piece of scrap "expanded" steel, that should do
...it's left over from either the Zero kart or the !Arriba! kart (can't remember)
Did some measurin', markin' & cuttin'
Once I had the (2) pieces, just had to "dry fit" 'em
...& trim off a bit more of the excess
(1) piece had a nice "finished" edge to it
...but, the other didn't so, I had to do some bodywork
Then, they got permanently attached with a bunch of "blob" welds :2guns:
After, lots & lots & lots of clean up (mostly smoothing rough spots)
Using the "WPI" (work piece indicator) concept
...feel, smooth, feel again & smooth some more, 'til it's super smooth :thumbsup:
Then, I wiped 'er down with some paint thinner
...but, kept finding more & more rough spots :ack2:
After a couple more "go overs" I think she's finally ready :wai:
While I was at it, I also, cleaned up the steering wheel & spindles :2guns:
Set up a mini paint booth in the back yard :thumbsup:
Still, just using' "rattle cans"
Gave 'er a final wipe down & shot 'er
Since, it's mostly bare metal I am using "Self Etching" primer
...it's supposed to "bite" better on clean metal:2guns:
Gave 'er ~1/2 hour to dry then, set 'er down
...& finished sealing 'er up good :thumbsup:
Hung the spindles & steering wheel
...& sealed 'em up too :cheers2:
Kinda reminds me of Army colors
...like an olive drab (off-greenishgray) :2guns:
Had some time so, I did some work on the seat :thumbsup:
Worked on the seat back first (the easier section)
Cut a piece of plywood to the desired dimensions
...used 1" thick "closed cell" foam rubber & ~1" of "fluff" to soften it up
& round the corners
A friend gave me some faux gator skin type of material
...it seems kinda thin
...but, looks kool so, I'll give 'er a shot :2guns:
Layed the plywood, foam rubber & the fluff out on the material
...trimmed around leaving ~3" on the sides & bottom for "wrap around"
I left ~ 16" of material @ the top "for wrap around"
...but, also to cover the back side of the plywood (for a cleaner look)
Marked the corners @ a 45* angle
…& sewed 'em up (straight first, then on a bit of an angle so the corners will curve nicely when flipped around the right way)
Stapled 'er all the way around
...then flipped the top "flap" down & stapled 'er down too :cheers2:
The seat bottom...
...the battery cut out was a major PITA :ack2:
I drew it out
...& kinda planned it out
...step by step
But, WOW super complicated to make a cover fit "good"
So, I ended makin' (3) seat covers before it came out "decent"
...not great but, passable
...third times a charm :cheers2:
