Now that part of the steering is pretty much complete, next is to work on the spindles
When I capped off the ends of the front axle, I angled the plates, where the spindle mounts to ~10*
(I read somewhere, that's how it's supposed to be)
...but, it didn't look right
So, I did some research
(back to the books, so to speak)
http://www.diygokarts.com/vb/showthread.php?t=11760&highlight=caster+camber
So, to set it up right, you have to keep in mind
...Caster (the angle of the spindle, when viewed from the side)
...Camber (the angle of the spindle, when viewed from the front)
...Toe Out (the angle of the spindle, when viewed from the top)
...& King Pin Inclination (an imaginary line thru the spindle main bolt (king pin) to the center of the tires contact patch)
But, it seems that there are no definitive answer
...there are a lot of variables
...& it depends on the specific situation (how the kart is designed & what you intend to do with it)
So, for this kart, I am going to
...set the Caster @~7-8* (10* just seemed like too much)
...redo the Camber, back to 0* (leaning front wheels just don't look right)
...& set it to Toe In just a bit (it's easily adjustable later)
Also, I am using factory made spindles so, there is isn't a lot I can do about the KPI (without extensive work)
Moving on (now, with more info)
I drilled 1/8" "pin/screw" holes in the center if both front axle end plates
Lined the spindle brackets (up/even) with the bottom of the axle tube
...& drilled corresponding "pin/screw" holes
This way I could "screw" them on (evenly on both sides)
...to more accurately place & adjust them
I can lean them "outward" to "fix" the Camber issue (that I caused)
It also allows me to "very accurately & evenly" adjust the Caster on both sides (to matching specs)
