This is why I don’t take them apart once put together. LolI'm no expert but that rod looks horrible. Piston not great either. Engine experts correct me if I'm wrong.
Would you recommend replacing the rod bearings?Looks like something ran through that engine, like grit.
I was thinking I could polish the journal, get new bearing (ARC 6292), flex hone the cylinder, …Polish crank first with some crocus cloth and a shoe string.
Was this engine ran with an aftermarket air filter that comes with those stage 1 kits???I was thinking I could polish the journal, get new bearing (ARC 6292), flex hone the cylinder, …
Do I need new rings? New Piston?
Maybe I wrote it wrong.Was this engine ran with an aftermarket air filter that comes with those stage 1 kits???
We have alot of gravel roads and red clay dirt around here, very dusty. I see the same piston, ring end gaps, cylinders, cranks, and rod bearings jus like yours, only after a few hrs of running those filters.
I think I had 11 bad blocks come in last year that was way too far gone because of those filters.
That piston and those compression ring end gaps, will cause alot of blow by and excessive crankcase pressures. You will be blowing gaskets and seals, especially with that blower.
IMHO, .005" ring end gap difference in the cylinder is too much for any decent mild build.
In a tiller, log splitter, or any other steady low rpm use would be a better place for it.
Jus my opinion,![]()
It was an estimated 0.0005” difference in ring gap between the top and bottom of the cylinder. Not 0.005”.
0.0175” top to 0.0170”.
So I think that means the bore is is less than 0.0002” wider at the top than the bottom.
The engine was only ran on a stand in my parking lot.
My air filter is a metal screen air filter from treatland. I quote here…
so nice screen air filter for limitless flow. fits on OKO 21mm, 24mm, 28mm and 30mm carburetors.
OD of the chromey part = 65mm
OD at the largest part = 75mm
total length = 37mm
ID = 48mm
"OKO - new yuppie fashion trend"
With a dry charge pre-filter like this zipped tied tight.
should I get some file to fit rings? If so, what gap do you think I should run with ~10psi boost and hot intake air temps?Pick up some magnetic oil drain plugs. They really help when breaking an engine in.
I've posted pics somewhere here about the magnetic oil drain plugs.
I would go by that ring end gap chart you had for boosted engines.should I get some file to fit rings? If so, what gap do you think I should run with ~10psi boost and hot intake air temps?
I looked quickly and saw that I could only find file fit for the top ring like you say.I would go by that ring end gap chart you had for boosted engines.
I usally have bigger problems with the piston to cylinder clearance after a hone. It's some thing that's gonna need checked. It might take 1 or 3 or 4 pistons to find the right fit.
That's me, I'm picky about the piston to cylinder and end gaps. I like to seal that cylinder the best I can.
I start a fresh build with no less then 3 pistons, and 3 ring sets. Usually from different suppliers.
You will only find "file to fit" top rings. They oversized. 005"- .010".
Again, it's gonna be 1 of those things that takes time and measurements.
You MIGHT NOT need file to fit rings,![]()
Yea, I think that would be best. You might get lucky and the "new" be perfect.......don't count on it,I looked quickly and saw that I could only find file fit for the top ring like you say.
0.0055” per inch of bore =
2.75 x 0.0055
would make the top ring gap about 0.015”
I’ll see what the new piston / ring gap combo is when it gets deliver.
Im not sure how much material the 240 grit flex hone will remove. The walls “feel” smooth to my finger.
total length = 37mm
ID = 48mm
