The Not So Cool Mini Buggy Build
n1kogr
Mass
little update
justang90
montreal canada
ok so if you want some advice on welding ive got alot of experience and by what i can see you got alot of skill between the begining of your kart and now.. i presume that you weld with rod enrobed but what kind ? if i remember the last time i weld with this proceed ive used 7018.. you need to find the reason of why you have to grind your weld after. the first thing i learn in my welding school is "dont grind your weld !" so if you have sparckle (dont know the name in english) you need to check :
a: did you make good prep to the steel ?
b: did you have the right polarity ? (AC welding is for garbage only !)
c: did you have the right angle ?
d: did you have enought heat or to much ?
e: what is the rod you used maybe its the problem ?
i can tell you that your weld will be strong enought now but why not continu to upgrade your skill ?
n1kogr
Mass
The reason i grind is because of the splatered dots i dont really grind my welds anymore but i think it is because of the fluxcore welder its always messy as much as i prep my steel i dont weld with rods thank you for the help its much appreciated
n1kogr
Mass
Got the front end back together feels and rides great
n1kogr
Mass
Because i wanted to allow for more spacers on the inside but it turns out it was a dumb idea.. i have a thread tap for this bolt so i might cut them back or just leave them not sure yet but honestly not too concerned about it.
n1kogr
Mass
ahhhhh poop i broke it again!! I should have done it right the first time ans used grade 8 bolts but now i need help finding them. Does anybody know where i could get grade8 5/8 11x7???
fowler
Bullsbrook West Aus
What is your bolt pattern
It might be time to do it properly
Get some proper axles and hubs from a quad or trailer
A grade 8 bolt is more likely to snap rather than the lower grades that have some flex
n1kogr
Mass
The heavy duty spindles have grade 8 bolts and are guaranteed to last just that its $100 dollars so i rather just rebuild mine
n1kogr
Mass
ehhh im not sure on that one but i just ordered two bolts for 10 shipped so well see how it goes with these installed or else im getting the new spindles and calling it a day
n1kogr
Mass
Got a little bored today so i tried to compact the rear a little bit. I think it looks alot better than before.
exenos
Project Nut
Whats the track and wheelbase on that thing? Have you gotten any air yet? I'm wondering how the suspension will take it.
n1kogr
Mass
not sure on the wheelbase but ive jumped it flipped it crashed it beat the crap out of it and the only thing ive had a problem with is the spindles
n1kogr
Mass
hahaha ik ik its just a lil yard cart really that i built with no knowledge about this sort of stuff what so ever... im just surprised it moves...
You've done well, you should be proud :thumbsup:
The thing I like most about this build is that every time you hit a hurdle, you ploughed on & figured out a way to get over it. IMO, that's the mark of a good craftman; discovering a problem, examining it, then figuring out the most efficient way to overcome it.
You have the skill, the knowledge & the common sense to create great things
