souperman000
Thanks for the compliments this thing was a blast to build now all i want to do
is ride hahaha
I know the feeling
is ride hahaha
Look through some of his more recent pictures, he uses two cables to shift. Press the lever forward and one of the cables moves the shifter on the engine forward. Pull the lever back and the other cable pulls the shifter on the engine back. If you can, a solid linkage or push/pull cable would be preferable.
Ok, thank you. The problem is that if you mount the engine on your rear swingarm, you won't be able to use a solid linkage.
