The Not So Cool Mini Buggy Build
n1kogr
Mass
new chain tensioner in.. Much simpler design without use of a spring. So far i rode the crap out of this buggy for a good 2 hours and i had absolutely zero problems with the chain falling off even with me beating on it so hard even jumping it on a lil hill a few times. So far the buggy is holding up great and its a blast to drive only thing ive noticed is my lower a arms have gotten a tiny bit of slack and turned at full lock i can see both wheels slightly jerking around.. other than that i am very happy!!!!
brandongeiger2
Valrico Florida
Is that a 420 or 428 chain? Because I was wondering if its 428 where you got the sprocket ive been looking for one that would bolt up to an aluminum hub like that.
n1kogr
Mass
uhhh ohhhhhh i think something broke :(
machinist@large
West Michigan, 49331
:surrender::ack2: Soooo, just how much air time did you get before the final landing? More than a skateboard at the "X Games"?
Seriously, that's pretty much a textbook example of cold lap. The only reason it lasted as long as it did was because the area of greatest penetration was at the bottom.
Looking at the parts in question, it looks like these were premade parts?
Well, you just outdid mysteryboy. nothing broke with his wheel toss.
That's gonna be a fun fix for you. Murphy's law says "if one side broke, the other side will break eventually"
B man
Tecumseh FTW!
Oliver springs,Tn
heres a trick. If you try this setup again then when you make the spindle drill the hole the size of the bolt you going to use and stick it through the back side then weld it from the back. should end up much stronger.
n1kogr
Mass
my plan is go get some thick plated steel and drill 5/8 holes in them and then go get a grade 8 5/8 bolt and use both sides of the spindle to weld it to opposed to the one side like this.. I think it will beef up the spindles pretty good
n1kogr
Mass
Started the spindle project but i got a little problem.. I went to lowes and got two 5/8 by 10" bolts but they have a little play when i put them in the hub bearings. Anybody know where i can get two 5/8 by 8" spindle bolts??
n1kogr
Mass
Pics
n1kogr
Mass
Thats most defiantly in the plans i just need to figure out what im going to do with the bolt
B man
Tecumseh FTW!
Oliver springs,Tn
wait. are your bearings us standard or metric? cause 5/8" is 5/8" no matter where you get it or in what form.
shouldnt have play if there 5/8'' bearings.
They may be 17mm. 5/8" = 15.87mm. That's a difference of 1.27mm or 0.05". 11/16" = 17.4625mm
You should've waited to weld the front plates on & fed the bolt from the back; they'd be much stronger that way. How hard would it be to cut them off?
n1kogr
Mass
I am going to feed the bolts from the back. I just have to drill the holes pretty easy then slide the bolt through... The hubs are from bmi and say they are 5/8 inner diamiter bearings but the bolts have a tiny bit of play as the old shafts fit more snug. Maybe ill bring the hub with me and see if they have any metric bolts of that length to fit
fowler
Bullsbrook West Aus
Well the bolts are probs not acctually 5/8
They never designed the bolts to be axles, the sizes are just a guide to help u choose the size u need
16mm is the best bet
All the bolts will be a tiny bit differant
How much play is "some" play
If u want a perfect fit then get some 17mm steel bar and get someone to lathe u up some accurate ones
Fed from the back & welded to the back aren't the same thing. How much access do you have from the back; from what I can see in the pics (we never do see the back) it's little to nothing.
Do you have vernier calipers? Measure the two shafts & see what you get. Also, measure the bearing.
Remember that, when a thread is cut, the OD of the thread ends up slightly smaller than the specified size. If your bearing is sitting on the thread, that's where the extra movement wil be.
Also, just because a bolt is 5/8" doesn't necessarily mean the shaft is 5/8", just that the thread is 5/8"
n1kogr
Mass
More work done on the spindles just need to weld them up front and back (correct bolts found)
