Starting the Frame
Not too shabby- I love recycling stuff!!!
I see some porosity in your welds. Make sure the steel is relatively clean and rust-free before welding. Take paint off, too.
redsox985
PA
I would upgrade to grade 5 or higher hardware before I took her out. Other than that, I like the crafty-ness of making your own parts. DIY at its finest.
EastCoast
Nova Scotia, Canada
If I get the 6.5 hp motor from princess auto they have two 3/4" Centrifugal Chain Clutches 10 or 12 teeth
#1 Bi-directional operation
Up to 13 HP
Sintered metal shoes for the ultimate in proper weight, wear ability, and heat dissipating qualities
10 teeth
#40/41 chain pitch
4" outside dia.
3/4" bore, #40/41 chain pitch
OR
#2 Bi-directional operation
Up to 13 HP
12 teeth
#35 chain pitch
4" outside dia.
3/4" bore, #35 chain pitch
What one do I want? They are both $59.99.
No doubt! I was into mine Tuesday and was wishing I could score one at that price.
Regarding the clutch, you can use either one. Obviously, #40 chain is stronger. Odds are good the #35 would be fine for you, and has the benefit of allowing a physically smaller rear sprocket. Your call. I'm usually guilty of overengineering things, so I'd go with the #40.
redsox985
PA
In fact, TS, you will need about the same sized sprockets to get the same gear ratio regardless of chain size. 35 needs more teeth around the clutch which means more on the axle for the same ratio. The only benefit of 35 is that there are many more split sprockets available which make changes much easier.
You're right- you got me on that one.... I was thinking about that last night trying to do the math in my head, but I pumped in a lot of overtime this week and I was ruined... OOPS!
Umm- okay, it's lighter, and at Princess anyway, the components are cheaper... (he says, sinking into his chair a wee bit ;) )
EastCoast
Nova Scotia, Canada
I was going to use mower wheels and tires. Should I use the smaller front wheels on the front and back or could I beable to use the lager rear wheels on the rear and the smaller front ones on the front?
I am picking up a 6.5hp Honda clone tomorrow.
Oh I also have a question about the rear axle I want to make a live axle (both rear wheels turn under power) but how hard will it be to turn?
EastCoast
Nova Scotia, Canada
Ok got a new motor sold the other two I had for $50 each so I made $100 and I got them for free I put the $100 towards the new motor and only payed $140 for the new motor.
redsox985
PA
Electronic ignition? Is there a starter on it or is that just some stuff they put on there?
That just means it uses CDI, or some other technology instead of breaker points.
Sure you can make your own seats! Cut shapes of plywood, pad with foam, upholster with leather or vinyl. Or, you can take one of those contoured plastic stacking chairs with the metal legs, and cut it off the framing. You can even bolster the sides with sheetmetal.
You could use the seat and back support off a weightlifting bench just as it is, if you like. Lotsa options!
They do seem to be less available now than they used to be, I was looking too. You could try contacting all the local schools and asking what they've got available. The legs were pretty notorious for bending and breaking under the abuse of a teenager, and the schools generally wouldn't bother repairing them.
