I think it would be simpler to have a manual choke. Two possible problems off the top of my head...
1) The hand crank thing is a crapshoot. It is unregulated, and who knows what its output is. It may not charge your battery worth a dang.
2) Some of these carbs don't use a choke in the conventional sense. They use a starter enricher circuit. Instead of restricting air, they add more fuel. Futhermore, there are some electric "choke" units that require power to be OFF. In other words, no power to the solenoid means you run horribly rich. You must then be sure to find a way to reliably deliver 12v to it, consistently.
