Slow Pocket Bike, only going 5km/h :(
Joshmcmillan
Coastal NSW, Australia
Engine revs but wheel dont move unless on stand? Its the clutch.
Engine revs up high on stand, and spins wheel. On ground, engine revs, but not as much as on stand, and wheel barley spins.
well thats what you get for buying chineese rubish
No, that's what I get for buying from a person without a sence of decency.
BradenM
Etre Et Durer.
In a big jar of Nutella, nom nom nom
My Chinese rubbish is more reliable then a GX25, genuine article. If you treat a GX200 clone (also "Chinese rubbish") like ****, what kind of performance can you expect? Thats right, ****.
There is absolutely nothing wrong with a stock 49cc pocketbike engine, and they can prove to be a reliable workhorse-when you get into serious engine modification, there lifetime can be reduced.
The reason Josh got screwed was because of the dishonest **** who sold it to him. Not because of the uncared for motor.
ZnsaneRyder
Crazy Guy on a Bicycle
FL
It definately seems like your clutch! Your engine seems to have plenty of power, but it's not getting to the wheel.
Sucks about the pocket bike, but I'd recommend keeping it, and replacing the clutch, or putting a big 4 stroke engine in the pocket bike with a go-kart clutch and making it fun.
A 6.5HP clone would make a really fast pocket bike.
SpyGuy
Hooligan
Tucson, Arizona
Well, here's what I'd do in your situation:
A) Buy a brand-new clutch for the bike, and try it, see if it works.
B) If that does not work, try a new clutch bell housing.
C) Pick up that other bike, so you would have TWO bikes, and get that one running well.
D) Part your original one out, and try making back your money off the parts.
I have four of these bikes, plus a bunch of parts. I figure I've spent at least $500 and then some for everything so far. Not a single one of the bikes was over $100, but at least one of them has an extra $100 in parts on it.
Ultimately, it's your call. I AM sorry to hear you got screwed like this, though - some people just don't have any sense of decency. Been there, done that - now I suspect everything that sounds too good to be true, even if it IS true.
P.S. Regardless of what these guys say, putting a bigger engine in that bike would simply snap the frame like a twig. Cags don't do well on engine swaps. Cateye frames, however ..... Several people have swapped in 6.5hp engines, both here and at PBP.com, and appently the swap isn't that hard - just some custom brackets for the engine, a new clutch setup, a few little odds and ends, and a set of wheelie bars on your butt to keep you on the seat for when you crack that throttle open ........
Joshmcmillan
What's a cateye frame?
I'm going to buy a performance clutch (still 3 shoe), as I probably would have got one eventually anyway.
I think my chain is the wrong type to.
The bike came with a new sprocket AND chain, but they were off the bike. The chain didn't fit on the sprocket on the bike so I took it off and put the other one on. I did not change front sprocket as well. It seemed to fit on so I just forgot about it. I don't think it's the problem because of the few times it went fast. Do I still need a new chain or will I forget about it as it seemed to spin properly?
thgrahamjr
Love To Build!
Clewiston Florida
I don't know about yours but my pocket bike has a #25 chain on it with a 6T clutch and 60T sprocket. I bought mine new for $200 off ebay about two years ago and it came with an extra pull rope assy, chain and clutch. The only problems I had out of mine besides adjusting the carb when I first got it was the pull rope and/or spring breaking.
Joshmcmillan
Reckon I should buy a clutch for around $20 (as I would probably want one now, rather then waiting and getting a cheap one). Or, get a whole engine, with clutch, starter, carby, air filter, throttle cap etc..., for $70?
SpyGuy
Hooligan
Tucson, Arizona
As long as your chain goes smoothly onto the sprocket and pinion gears without binding, it should be okay. Most pocketbikes have #25 chain - mine came with a 6/68 gearing setup (6th pinion in front, 68th sprocket in the rear).
Actually, I'd go for the $90 option - get both the engine AND the extra clutch. That way you not only get the clutch working, but you also have a complete motor, just in case ....
The FS509 Cateye is a 49cc pocketbike with dual headlights and taillights (not street-legal). They are commonly referred to as "Crap-eyes" because of the unreal amount of problems these bikes seem to have. However, the frame is surprisingly adaptable for an engine swap to an upright Briggs&Stratton or Honda 3.5-6.5hp motor with little modification (custom brackets need to be made and welded onto the frame, plus a new minibike clutch and chain drive). Here's a link to a picture of the bike:
http://www.scooterparts4less.com/49cc_pocketbike_parts.htm
Here's a thread on PBP.com about a "modded" cateye with engine swap:
http://www.pocketbikeplanet.com/f129/196cc-cateye-46015.html
SpyGuy
Hooligan
Tucson, Arizona
That's the way to do it. You may wait a bit longer instead of getting it right NOW, but the wait is usually worth it. I picked up all my bikes from craigslist, one in almost brand-new condition. A couple of bikes I bought for parts (try $50 for a parts bike with a good strong running engine! How much is a brand new engine again ....?)
Saddletramp1200
Houston, Texas
Does your clutch smell burned, it will stink, and take the air cleaner off, and see if the choke is level to the earth when it's "off" . Also timing, points, carb, AHHHhahhh Opps, sorry.
Joshmcmillan
I tried to take the clutch off today and it wouldn't come off!! I took the pull starter off and held on to the flywheel with vice grips and a cloth, then put vice grips on the other end, and it just wouldn't budge. What do I do?
Phatvortex
WD40 won't work, it isn't seized, just torqued on.
A strap wrench is a tool that has a strap made of a friction-y material that you can tighten onto things like pipes or flywheels to undo them.
