Sled Rebuild
crazycart
RedNek Engineering
MINNESOTA
Well the 500 LC's arent very fast to start with, about 90 MPH sleds. The 650 will do 110+ with good hardpack conditions.And it looks like sleeper til ya fire it up, them triples sound awesome.Its got 96 studs, but needs more because of the power.
For summerizing we usually do that or spray marine storing spay into the carbs and down the plug holes. Also run it dry.
Kenny_McCormic
Kartless....
Michigan Troll
snowmobiles are so fun. Want to know a real sleeper snowmobile. Our 85 ski doo MX 470 LC. Some how, stock set up, keeps up and or passes my aunts 98 polaris 500 LC. Has not been re-built it in a long time. the primary has a odd noise but we feel if it aint broke dont fix it.
On another note how do you "summerize" or store your sleds? we always run seafoam or stai-bil through like 5 gallons and run the carbs completely dry. Us personally have never had any problems.
Carbs should be left full of treated gas so should the tank if metal, Spray some WD40 down the plugholes so it doesn't seize up.
crazycart
RedNek Engineering
MINNESOTA
Pics of the engine mocked up, just need gaskets.
newrider3
Colorado
My friend said he just got in a new pipe, Fox shocks, and a turbo for his sled. I believe it's a Polaris Triple. Yes, I said turbo.
crazycart
RedNek Engineering
MINNESOTA
Turboing a 2 stroke is pretty close to pointless.
You sir, are completely wrong.
Turboing a 2 stoke makes INSANE horsepower. But of course, is very hard to tune. Usually not necessary unless mountain climbing or drag racing, because its very complicated and expensive to set up. It may seem like it would be pointless on a 2 stroke, but it makes ridiculous power.
crazycart
RedNek Engineering
MINNESOTA
The thing is, the intake and exhaust ports aren't exactly in line, and with the powervalves on modern 2 strokes, it works. There isn't a better power adder than this, horse power can be increased by 45-50%. And that's big numbers when you have a sled that's running 175hp stock.
Kenny_McCormic
Kartless....
Michigan Troll
I wish I still had that 650. Dad just had to get rid of it before I got the cash around to rebuild it(and he gave it away at that). This thing was ****ing sweet, 650 3 cylinder liquid cooled fuel injected 2 stroke with studed track, a Polaris indy IIRC. Dealer wanted $200 for the piston it needed.
crazycart
RedNek Engineering
MINNESOTA
That would be a Polaris RXL. Same as the one i have, just with fuel injection. These had 44mm intakes too. My dad had 3 of them. Fast sleds.
crazycart
RedNek Engineering
MINNESOTA
A twin cylinder 38 horse a bit more than a little 5 horse..the thing shakes the strap loose lol...
