Rear wheel drive with rear wheel steering??
dthomp87
I have an off road skate board and it is only one wheel drive in the back right tire. I took out the old motor and put a 148cc 3.5 B&S Engine on and i want to make it two wheel drive.
here is the issure and where i need help..
skate boards use front and rear axles for steering.. so would a Locked live axle in the rear make the skate boards steering terrible? i know i should use a differential but theres not much room back there..
modelengineer
Lord of the noise
Sydney, Australia
With the back wheels so close together and the turning circle of (typical) skateboards being quite large I don't think you will have any problems running a live axle.
However, I'm not sure how the steering on the rear of a skate board works but it might not be possible to put a solid rear axle there. Maybe someone with a bit more knowledge of skareboards will be able to contribute.
sayre315
Rupp enduro
Oklahoma
i skate like ummm alot with my freinds and the skate board turns using the trucks wich pivit on a diaganal bolt goind verticle with 2 bushings
i think in his setup the engine is atatched to the rear truck so that the chain wont tighten and loosen when turning
i just found this
watch it
http://www.youtube.com/watch?v=d_HQvXvpv1Q
dthomp87
yes and since that is how it steers, if i am just sitting in one spot not going anywhere and I lean in a certain direction (like im trying to turn) the front turns one way and the rear turns the other.. enableing a nice little turn radius.. but if im just sitting in one spot and lean.. on the back wheels, one moves forward and the other moves backwards ( to enable the turn) and if i have a fixed locked axle then this wouldnt be possible. now im not sure if this would have much effect on steering once have reached a high speed.. but it could be a large issue at low speeds.. but on the other hand it could even make the board more stable at high speeds..
who knows
i just know one i start the process, there is no turning back
dthomp87
I was just looking at a different gas powered skateboard manufacturer and they have two wheel drive in the rear.. they do this by using a 'semi-differential'
heres a link
now i have no idea what the hell that means or if its possible to buy one.. anyone know about this semi-differential??
sayre315
Rupp enduro
Oklahoma
i know a differetnial is kinda like a drill
all you know how some drills have those differant numbers on there that at a sertan pressure they start clicking and the motor turns but the drill bit doesnt?
thats kinda how a differential is
it lets one wheel turn faster than the other one so that the wheels are not completely locked up together
ed1380
Banned
ATL, GA
yes it does. point number 8 has a link to a supplier :p
although a good one is a junk yard. one that you take off the parts yourself
kibble
I banned myself
Well, I didn't build the diff, I just adapted it from a car diff.
