So this is kind of up my price range, have the cash for it. Idk trash or smash? Its down the road from me.
Possibly. However the title would know for sure if its accurate. But they still have a TON of aftermarket support. Curious what under the vehicle looks like though. Probably only has the TH350. But could easily drop in a 700R4 in its place or 4L60E with very few mods.30,000 miles in 50 years? Bet there is more this story.
As you can imagine I owned a SS454 version (last year they offered it) for almost 20 years. Before my EX-wife gave it away without my knowledge. They are great vehicles and ride fantastic. But they can only haul about 500 pounds in the bed comfortably. Check floors and smugglers box for rust. Door bottoms and fender bottoms are very bad also along with bed crossmembers and body mounts.So this is kind of up my price range, have the cash for it. Idk trash or smash? Its down the road from me.
Yea, as WTR says, took some weight off the weights in the driver of a 40 series. The goal was to remove 30g but to go any further, I would have had to buy a new drill bit set as I broke every one up to the size you see in the weights. Few broke off inside the weight. Those were fun to remove. Caused two more to break off inside. Several broken bits and a screaming, sad sounding drill later, worth it! Keeps it in low long enough to smoke the tires on the road.What is it?
While the process and result sound "fun", I am actually surprised someone does not sell weights of different size/weight to achieve the tunability you have created.Yea, as WTR says, took some weight off the weights in the driver of a 40 series. The goal was to remove 30g but to go any further, I would have had to buy a new drill bit set as I broke every one up to the size you see in the weights. Few broke off inside the weight. Those were fun to remove. Caused two more to break off inside. Several broken bits and a screaming, sad sounding drill later, worth it! Keeps it in low long enough to smoke the tires on the road.
I was looking for a little more "hold" in low. My poor red spring cant take anymore tension. I need a yellow in my "further drilled" hole. I really make this engine work for the shift.I drilled more holes in my 40 driven like the 30. Gave the spring more tention.
It holds low gear longer and will also light the tires up.
You can see the holes here and the key trying to shear. Lol
Comet sells heavy, medium, and light versions.While the process and result sound "fun", I am actually surprised someone does not sell weights of different size/weight to achieve the tunability you have created.
