I'm gonna take everything back apart today thank you!!Did you align the cam and crank timing marks?
Did a lifter fall out during install?
Is the valve lash set properly?
Does the flywheel have a key? Is it aligned properly?
Coil gapped properly?
Spark plug wire on?
Gas in the tank?
Gas in the bowl?
Switch turned on?
I might try this think its the cam?? we'll see i'll report backSo remove the parts that make it run, add new parts, now it doesn't run. If it was me I would put the old parts back on and see if I could get it to run. It might be edu-ma-cational.
I've been working on it chillThe guy hasn't been back since an hour after his post. Might be another one of those.
Lo206The list that WTR took the time to type out is just senseless logic. I wonder if a troubleshooting flowchart would work with it?
English version:
I want to see pics of the engine, or the “Briggs slider carb” in particular.
I didn't think it needed them I didn't put rockers on it yet...?? Am I wrong?Lash cap on?
