predator 212 start problem
The list that WTR took the time to type out is just senseless logic. I wonder if a troubleshooting flowchart would work with it?
English version:
I want to see pics of the engine, or the “Briggs slider carb” in particular.
Imagine this gen using a card catalog and writing down numerous notes, then having to use the DD system and find a book in a building full of books to find any info your looking for.
Or buying a magazine and waiting a whole month for the next edition to come out so you can read part 2 of how to....
Culljeff
Did you align the cam and crank timing marks?
Did a lifter fall out during install?
Is the valve lash set properly?
Does the flywheel have a key? Is it aligned properly?
Coil gapped properly?
Spark plug wire on?
Gas in the tank?
Gas in the bowl?
Switch turned on?
I'm gonna take everything back apart today thank you!!
