predator 212 start problem
Culljeff
Hey on my pred I added a cam valve springs and flywheel with a Briggs slider carb but it wont start??
The list that WTR took the time to type out is just senseless logic. I wonder if a troubleshooting flowchart would work with it?
English version:
I want to see pics of the engine, or the “Briggs slider carb” in particular.
The guy hasn't been back since an hour after his post. Might be another one of those.
Imagine this gen using a card catalog and writing down numerous notes, then having to use the DD system and find a book in a building full of books to find any info your looking for.
Or buying a magazine and waiting a whole month for the next edition to come out so you can read part 2 of how to....
Culljeff
Did you align the cam and crank timing marks?
Did a lifter fall out during install?
Is the valve lash set properly?
Does the flywheel have a key? Is it aligned properly?
Coil gapped properly?
Spark plug wire on?
Gas in the tank?
Gas in the bowl?
Switch turned on?
I'm gonna take everything back apart today thank you!!
Culljeff
So remove the parts that make it run, add new parts, now it doesn't run. If it was me I would put the old parts back on and see if I could get it to run. It might be edu-ma-cational.
I might try this think its the cam?? we'll see i'll report back
