Get a 32mm intake and 32mm carburetor. You'll thank me later I promise you. Mine gonna be probably a lectron and a 34-40 ! With my other engine after goofing off with the stocker for awhile.
If get the cheapo knockoff, what do you like? The Mikuni round slide vm32?
http://www.ebay.com/itm/carburetor-...-Slide-Carb-Carburetor-VM32-282-/321924161335
or the Keihin flat slide PWK32?
http://www.ebay.com/itm/Carburetor-...ash=item41a7c1d448:g:XjMAAOSwdU1W~WuR&vxp=mtr
---------- Post added at 08:53 PM ---------- Previous post was at 08:51 PM ----------
I laid down one night tired and work up one morning with this.
Ported, Milled, Machined Big Valve Head with Automotive Keepers, retainers, ss Valves,.... 285.00
http://www.bullfrogmotosport.com/ProductDetails.asp?ProductCode=PCHKBBC
SS Valve HD Spring Retainer/ Keeper Kit 20.00
http://www.bullfrogperformanceproducts.com/product-p/100.2018.htm
35mm (stock size) SS Intake Valve 21.50
http://www.bullfrogperformanceproducts.com/product-p/100-1024.htm
40mm SS Intake Valve (needs valve seat work) 21.50
http://www.bullfrogperformanceproducts.com/product-p/100-1022.htm
31mm (stock sizr) SS Exhaust Valve 21.50
http://www.bullfrogperformanceproducts.com/product-p/100-1030.htm
33mm SS Exhaust Valve (needs valve seat work) 18.00
http://www.bullfrogperformanceproducts.com/product-p/100.2010.htm
2,4,6,8 degree Offset flywheel key 6.99
http://www.nrracing.com/product-p/nrkey.htm
Cut to Length Co-Mo push rod 14.00
http://www.arcracing.com/dj-3070cl-gx390-chromoly-cut-to-length-push-rod/
6.54" Co-Mo Push Rod 14.00
http://www.arcracing.com/dj-3070cm-gx390-chromoly-6-54-push-rod/
HD valve springs 10.00
http://www.nrracing.com/product-p/nr-966-s.htm
HD valve spring 4.00
http://www.arcracing.com/dj-3055hd-gx390-heavy-duty-valve-spring/
Cr-Mo Push Rod 1/4" 14.00
http://www.nrracing.com/product-p/cmpr-65.htm
SS Valve HD Spring Retainer/ Keeper Kit 6.5mm 25.00
http://www.nrracing.com/product-p/390retainerskprs-alum.htm
Bronze 6.5mm Valve Guide 14.00
http://www.nrracing.com/product-p/390bronzeguide.htm
Cr-Mo Push Rod 1/4" 25.00
http://www.vegascarts.com/product-p/manton.htm
HD Valve Springs 35lb 16.00
http://www.vegascarts.com/product-p/gp966.htm
Offset Timing Key 8 degrees 7.00
http://www.vegascarts.com/product-p/tkey.htm
MACHINE WORK Porting and Milling 150.00
http://www.vegascarts.com/product-p/portmill.htm
32mm Billet intake manifold 40.00
http://www.vegascarts.com/product-p/inman.htm
http://www.ebay.com/itm/35LB-HD-VAL...ash=item2a6c9e4e8a:g:8xAAAOSw3YNXXxuY&vxp=mtr
Carburetor 32mm PWK Racing Flat Side Carb Scooter ATV Go Kart PIT DIRT BIKE 33.00
http://www.ebay.com/itm/Carburetor-...5d99749&pid=100005&rk=5&rkt=6&sd=262164767869
Set 10 Main Jet for Keihin OKO KOSO PE PWK Carburetor Available Size 80 -200 13.00
http://www.ebay.com/itm/Set-10-Main...ffType=OrderSubTotalOffer&_trksid=p5731.m3795
KOSO 32mm Performance Carburetor for 250cc ATV, Dirt Bike & Go Kart 30.00
http://www.ebay.com/itm/KOSO-32mm-P...-Go-Kart-/262164767869?_trksid=p2352135.l4275
10 x SLOW PILOT JETS JET for Keihin CARB Box Included 30,33,35,38,40,42,45,48,50,52 11.00
http://www.ebay.com/itm/10-x-SLOW-PILOT-JETS-JET-for-Keihin-CARB-Box-Included-/281978903073
Billet Intake Manifold Kit for Mikuni 32mm and 34mm Carburetors 46.00
http://www.bullfrogmotosport.com/product-p/intake-kit-mikuni-32mm-34mm.htm
Keihin Carb 32MM PWK Carburetor Kit With Power Jet Black Scooter 35.00
http://www.ebay.com/itm/Keihin-Carb...it-With-Power-Jet-Black-Scooter-/271731062051
54mm air cleaner 3.00
http://www.ebay.com/itm/Double-Laye...ash=item25c0844430:g:AHYAAOSwe7BWwTuP&vxp=mtr
2300-6000+ cam 120.00
http://www.vegascarts.com/product-p/pwrcam.htm
1800-5000 cam 50.00
http://www.vegascarts.com/product-p/tqcam.htm
55 lb dual springs 20.00
http://www.vegascarts.com/product-p/gp966-2.htm
65 lb dual springs 18.00
http://www.nrracing.com/product-p/gp966-2.htm
1.1 ratio rockers (welded and reinforced) 40.00
http://www.nrracing.com/product-p/reinfrockers390.htm
50mm Air Filter Pod 3.00
http://www.ebay.com/itm/New-50MM-In...ash=item5683b54d83:g:2~gAAOSwoBtW6iSa&vxp=mtr
KOSO 30mm Carb 30.00
http://www.ebay.com/itm/like/161794644208?lpid=82&chn=ps&ul_noapp=true
Keihin Carb 30mm PWK Carb 40.00
http://www.ebay.com/itm/Keihin-Carb...315abbe&pid=100033&rk=6&rkt=8&sd=141752216178
OKO 30mm flat slide carb 37.00
http://www.ebay.com/itm/OKO-30mm-PW...Stocking-/152175996651?_trksid=p2352135.l4275
