Powerland 420cc GAB 2.0
  • 32mm OEM KOSO OKO Carburetor Carb Power Jet Racing Scooter Dirt Pit Bike ATV.jpg
Jfive
Great falls Montana
I've debated the same, but the wife asked me to not spend money on her buggy yet so I haven't. There so cheap its hard not to just buy one to try out. Have had so many little projects since getting back on here though.
Jrgunn5150
Rudderless
I would stick with the Mikuni, or the clone variant that is easy to adapt and jet, and is a known quantity. Especially for the same price.
Jrgunn5150
Rudderless
My Chinabike has the VM26 (Clone), the largest diameter is 30mm, but the throat is 26. I think that's where thing's got lost in translation for the clones.
So for a 420cc four stroke that will turn 6, maybe 7k....
The suggestions have been 30 - 32 mm.
That is something like a Mikuni VM30 - VM32-33 correct?
To work with that 32mm adapter I've been posting from vegas carts?
Jrgunn5150
Rudderless
Correct, sounds right. My Chinabike is advertised as being a 250, but is actually like 229 or something.
Joe-405
Enjoying New Projects
U.S.A.
Get a 32mm intake and 32mm carburetor. You'll thank me later I promise you. Mine gonna be probably a lectron and a 34-40 ! With my other engine after goofing off with the stocker for awhile.
If get the cheapo knockoff, what do you like? The Mikuni round slide vm32?
http://www.ebay.com/itm/carburetor-...-Slide-Carb-Carburetor-VM32-282-/321924161335
or the Keihin flat slide PWK32?
http://www.ebay.com/itm/Carburetor-...ash=item41a7c1d448:g:XjMAAOSwdU1W~WuR&vxp=mtr
---------- Post added at 08:53 PM ---------- Previous post was at 08:51 PM ----------
I laid down one night tired and work up one morning with this.
Ported, Milled, Machined Big Valve Head with Automotive Keepers, retainers, ss Valves,.... 285.00 http://www.bullfrogmotosport.com/ProductDetails.asp?ProductCode=PCHKBBC
SS Valve HD Spring Retainer/ Keeper Kit 20.00 http://www.bullfrogperformanceproducts.com/product-p/100.2018.htm
35mm (stock size) SS Intake Valve 21.50 http://www.bullfrogperformanceproducts.com/product-p/100-1024.htm
40mm SS Intake Valve (needs valve seat work) 21.50 http://www.bullfrogperformanceproducts.com/product-p/100-1022.htm
31mm (stock sizr) SS Exhaust Valve 21.50 http://www.bullfrogperformanceproducts.com/product-p/100-1030.htm
33mm SS Exhaust Valve (needs valve seat work) 18.00 http://www.bullfrogperformanceproducts.com/product-p/100.2010.htm
2,4,6,8 degree Offset flywheel key 6.99 http://www.nrracing.com/product-p/nrkey.htm
Cut to Length Co-Mo push rod 14.00 http://www.arcracing.com/dj-3070cl-gx390-chromoly-cut-to-length-push-rod/
6.54" Co-Mo Push Rod 14.00 http://www.arcracing.com/dj-3070cm-gx390-chromoly-6-54-push-rod/
HD valve springs 10.00 http://www.nrracing.com/product-p/nr-966-s.htm
HD valve spring 4.00 http://www.arcracing.com/dj-3055hd-gx390-heavy-duty-valve-spring/
Cr-Mo Push Rod 1/4" 14.00 http://www.nrracing.com/product-p/cmpr-65.htm
SS Valve HD Spring Retainer/ Keeper Kit 6.5mm 25.00 http://www.nrracing.com/product-p/390retainerskprs-alum.htm
Bronze 6.5mm Valve Guide 14.00 http://www.nrracing.com/product-p/390bronzeguide.htm
Cr-Mo Push Rod 1/4" 25.00 http://www.vegascarts.com/product-p/manton.htm
HD Valve Springs 35lb 16.00 http://www.vegascarts.com/product-p/gp966.htm
Offset Timing Key 8 degrees 7.00 http://www.vegascarts.com/product-p/tkey.htm
MACHINE WORK Porting and Milling 150.00 http://www.vegascarts.com/product-p/portmill.htm
32mm Billet intake manifold 40.00 http://www.vegascarts.com/product-p/inman.htm
HD Valve Springs 35lb 16.00 http://www.ebay.com/itm/35LB-HD-VAL...ash=item2a6c9e4e8a:g:8xAAAOSw3YNXXxuY&vxp=mtr
Carburetor 32mm PWK Racing Flat Side Carb Scooter ATV Go Kart PIT DIRT BIKE 33.00 http://www.ebay.com/itm/Carburetor-...5d99749&pid=100005&rk=5&rkt=6&sd=262164767869
Set 10 Main Jet for Keihin OKO KOSO PE PWK Carburetor Available Size 80 -200 13.00 http://www.ebay.com/itm/Set-10-Main...ffType=OrderSubTotalOffer&_trksid=p5731.m3795
KOSO 32mm Performance Carburetor for 250cc ATV, Dirt Bike & Go Kart 30.00 http://www.ebay.com/itm/KOSO-32mm-P...-Go-Kart-/262164767869?_trksid=p2352135.l4275
10 x SLOW PILOT JETS JET for Keihin CARB Box Included 30,33,35,38,40,42,45,48,50,52 11.00 http://www.ebay.com/itm/10-x-SLOW-PILOT-JETS-JET-for-Keihin-CARB-Box-Included-/281978903073
Billet Intake Manifold Kit for Mikuni 32mm and 34mm Carburetors 46.00 http://www.bullfrogmotosport.com/product-p/intake-kit-mikuni-32mm-34mm.htm
Keihin Carb 32MM PWK Carburetor Kit With Power Jet Black Scooter 35.00 http://www.ebay.com/itm/Keihin-Carb...it-With-Power-Jet-Black-Scooter-/271731062051
54mm air cleaner 3.00 http://www.ebay.com/itm/Double-Laye...ash=item25c0844430:g:AHYAAOSwe7BWwTuP&vxp=mtr
2300-6000+ cam 120.00 http://www.vegascarts.com/product-p/pwrcam.htm
1800-5000 cam 50.00 http://www.vegascarts.com/product-p/tqcam.htm
55 lb dual springs 20.00 http://www.vegascarts.com/product-p/gp966-2.htm
65 lb dual springs 18.00 http://www.nrracing.com/product-p/gp966-2.htm
1.1 ratio rockers (welded and reinforced) 40.00 http://www.nrracing.com/product-p/reinfrockers390.htm
50mm Air Filter Pod 3.00 http://www.ebay.com/itm/New-50MM-In...ash=item5683b54d83:g:2~gAAOSwoBtW6iSa&vxp=mtr
KOSO 30mm Carb 30.00 http://www.ebay.com/itm/like/161794644208?lpid=82&chn=ps&ul_noapp=true
Keihin Carb 30mm PWK Carb 40.00 http://www.ebay.com/itm/Keihin-Carb...315abbe&pid=100033&rk=6&rkt=8&sd=141752216178
OKO 30mm flat slide carb 37.00 http://www.ebay.com/itm/OKO-30mm-PW...Stocking-/152175996651?_trksid=p2352135.l4275
Jrgunn5150
Rudderless
Jrgunn5150
Rudderless
I wasn't sure if that KOSO OKO knockoff thing was same as this one. I think it was, but not sure???
They look the similar, but not the same. Probably like a Predator VS the other clones, that are more cloney
Intake for 420cc Clone Engine (complete)???
This CARB
Keihin (style) PWK Flat Slide 32mm
$33
PWK 32mm Carburetor
Size:
Diameter(mm) 32
Outer Diameter to Air Filter: 54mm
Outer Diameter to Intake: 40mm
Color Gray Black Color
Package includes: 1x 32mm Carb
1 X Main Jet #120
1 X Main Jet #140
1 X Pilot Jet #40
and fuel pipes. Just same as picture shown.
If you need other size main jets, please choose from the top.
http://www.ebay.com/itm/Carburetor-...7c1d448:g:XjMAAOSwdU1W~WuR&vxp=mtr&rmvSB=true
Same seller sells 10 piece Main Jet kits.
$13
Jet sizes available 80-200
And 10 Pilot Jet Kits
$11
Sizes 30-75 available
http://www.ebay.com/itm/10-x-SLOW-P...in-CARB-Box-Included-/281978903073?rmvSB=true
54mm Air Filter
$4
http://www.ebay.com/itm/54mm-Univer...ash=item3f5e649c6b:g:0MQAAOSwmmxW47Xp&vxp=mtr
Some 1 5/8" silicon hose like this
$4
http://www.ebay.com/itm/like/262002129760?lpid=82&chn=ps&ul_noapp=true
32mm Billet adapter
$40
http://www.ebay.com/itm/32mm-Billet...se-with-GX340-GX390-GX420-GX440-/181902400746
So all together just over $100 with shipping.
Joe-405
U.S.A.
Just ordered the Koso 32mm. Hope it fixes my issues ! Mine only runs good when. Not under load.
I got the carb, 8* key, so we shall see. If it does the same thing. I guarantee it's the flywheel and coil. I hope my exhaust is just needing more air to run right. I wanted a lectron but done wanna put it on the stock engine. It's going on my stroker build.
Joe-405
U.S.A.
Carb is here. Fyi it came with extra jets and the intake boot and clamps !
