Post your finished projects!!!
Mike_D
Richmond, VA
my Clark Cyclops 440 restoration
Pics of my Clark Cyclops 440 restoration. My cart from early 1980s, spent countless hours and summers riding it. Restored so my son can ride it again (in a few years). Added the pipe behind the axle under engine plate and strengthened the joints on seat pan. All that's left is to get a new seat made.
n3480h
NW Iowa
Fox II finished
Finished the kart today. Everything works well, engine is perfect, and it's a plush ride for the grandkids. Before and after pics here. There's a build thread with more detail pics.
bshinn
China Grove, NC
Here's what I brought home!
Looked a HELLUVA lot better in the eBay add :lolgoku:
bshinn
China Grove, NC
After my fab guy got his hands on it........Thanks Chris
bshinn
China Grove, NC
And as it sits now, BTW it's an 84 Margay Xpert-II according to Keith at Margay. It's been a 2 yr odyssey to this point, the plan for the winter is a final teardown frame mods, powder, & chrome, then it should be finished.
Would like to find some original Series 62 wheels/hubs, if anybody has lead please contact me.
Even with just a KT100, it's amazing how fast this thing is with my 48yo 6'0" 230# A$$ on it! :lolgoku:
BobbyD963
Bought a Manco go kart with a blown engine for $50. I welded a roll cage to it, hooked up a horn from a Toyota Tacoma to the front bumper, chromed the pedals, put a harbor freight engine on it, got rid of the slicks, mounted a shotgun holder that I removed from a cop car so it can hold airsoft guns and did some graphic design work to it and gave it to my step son yesterday for Christmas. He liked it. I have about $350 into it.
BigDuke6
For the racers:
BLACK 3 CAR 2015, top class CAMMER upgrades.
No idea why it's called that.
6 new rear bearings, 2 per plate below each shock.
hoping for more durability/stability there.
4 new front bearings, 4 new Tanner Gen 2 Shocks.
Removed restrictor plate, cut and tweeked new candy cane header, timing to 4 degrees advanced,new gas tank,new body, new clutch 11T > 55T. New matched 8.1x11.5 dia rear tires, 6x10 fronts. 2 weeks to tech and practice. :cornut:
https://www.youtube.com/watch?v=um5FXe_qOuU&feature=youtu.be
Hybridyne
Got my two army mules completely done this weekend. One is all electric and the other has a Honda 125cc Motor with electric start and reverse.
Fun Project !!!
Hats off to Dewies
GoKartRstoration
Crazy Texan
College Station Texas
The murray was called the blue beast. Yerfdog was called bumblebee. Murray was powered by a 6.5hp HF engine, and the yerfdog by a honda 5.0hp pressure washer motor. Yerfdog had a 12 tooth clutch, 60 tooth sprocket, and 18 inch tires, was used on pavement and clutch never burnt up. Merray had a 12 tooth clutch which went to about a 24 tooth jackshaft which was converted to a 32 tooth sprocket and from that 32 it went down to a 42 tooth sprocket on the axle. Tires were 18 inches i believe and it was used off road mostly, although it had enough power to spin its tires from a dead stop on pavement.
bigair49
Southern Ontario Canada
This is My scratch built Power Wheels conversion
90's Power Wheels Barbie Jeep
all steel frame
50cc 2 stroke engine/electric start
13" turf saver tires
Before:
After:
My son pulled his sister in the CANADA DAY parade at the age of 4.
And some Glamour shots
And here is the full build thread. http://www.diygokarts.com/vb/showthread.php?t=8338
big-d
Mapleton, Utah
This project isn't quite done. (Are they ever?) It is a YerfDog 3020 that I rebuilt for my kids. It has 19 inch ATV tires on all 4 corners.
