Poboy kartman
Senior Moments Member
Well...the fender hit....but it was bent...a little persuasion with a sledge and it clears nicely now. However, the scrub brake is almost worn through (looks like it was a cast aluminum piece originally....still not sure how I'm gonna fix that! )....anyway is pretty close....but if my eyeballs are correctly calibrated....I think the holes in the frame are 3/4" and my bearings are 5/8".....so while I'm at it....I'll just move the axle further back a leetle bitty bit.
Now....width wise....got about 1 1/4" to work with between tire width and frame width....so doable...but like I said ....pretty tight.
I do believe if I do finish this build...I'm going to have to start a "Cliff notebuild thread"....
