Poboy's 2016-17-18-19.....??? build off entry
Poboy kartman
Senior Moments Member
White Settlement Texas
Poboy kartman
Well, the HF wheel, the sprocket, the TOO wide dumpster tire, and the one I bought yesterday....
Going to look at that bicycle tire and do a little mock up later on .
Poboy kartman
Naw...I can read....I can read....I can read....don't know what it means.....but....I can read...I can read...I can read.....
HEY MIKEY!!!!! I can read!
Atlanta, GA
You two picking on me now? When will it end??????? When Bob is finished? When FR produces actual results? When the moon splits open and spills smarties all over the planet?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Wait! The moon is filled with Smarties?
Spill that sucker! I love smarties.
and it is waaaaay more likely than FR learning to spell "i"
Poboy kartman
Arrgh! I was finally going to mock up the rear wheel today. Well, after hunting for 15 minutes to find the clutch, I found out it doesn't fit!
See....the original plan was a 2hp B&S . Didn't even think about the 3.5 Tech having a bigger pto! DOH!
Time to order a new clutch!
Poboy kartman
Well...this is getting interesting....even without a clutch...a quick eyeball tells me I'm either going to have to run the clutch backwards or move the engine mount plate....(and the engine is already hanging out that side.)
So...I guess I'll set the sprocket up as close as possible to the tire and rely on spacers to align it.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Just run the clutch inboard. That is what I had to do as well to keep everything within my "Krate"
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I know what you meant, (I am Fluent in "Poboy" by now) I was just sayin Dont sweat it!
I B T P S!
Poboy kartman
Yeah...and what I was saying is that makes the rear tire/sprocket set-up even tighter!
And I wonder if the fender will clear and the scrub brake will be tight....(not only to the tire....but look at how close it will be to the PTO bolt head! )
