old B&S 3 hp engine
jr dragster T
Cold place
Stick a long screwdriver down the sparkplug hole and measure the stroke. If it's 1.5", then it's a "5", which is good for 1- 1.5hp. If the stroke is 2", then it's a "6", which is in the 1.5- 2 hp range. These motors were built in (I think) the late 40's to late 50's.
Not real "performers", but interesting, none-the-less.
Or use a caliper.:cheers2:
Russ2251
AZUSA:Powered by LAWN-BOY
Are these old engines worth a lot of money?
Only if it's NOS (New Old Stock), and would have to find the right buyer. Check Ebay. There's still tons of them (used) out there.
Example of 6s:
Ebay 6s
Example of 5s:
Ebay 5s
6s tends to have more value because of it's 5/8" shaft.
The 5s has a 1/2" shaft and for this reason is not 'kartable' unless a 1/2" bore direct drive sprocket is used.
Nice thing about these engines is, if they through a rod, no damage will be done as block is cast iron.
Can't say that about their aluminum counterparts.
jr dragster T
Cold place
Hmm....I think I'd be able to get a nice hole in the block. Then again if they are so beefy the rod wont be breaking anyway.
ZnsaneRyder
Crazy Guy on a Bicycle
FL
In that case, it seems better just to get a cheap 5/8" $30 Max-Torque 11T clutch for it, and put it to use.
As far as power goes, is 25Mph a good speed to expect from it with the right gearing?
modelengineer
Lord of the noise
Sydney, Australia
My 3.5hp 2-stroke cast iron tec got my kart to 25, and it would go faster with a decent exhaust and if I modded the throttle so it opened all the way up.
I think a B&S 3hp will get you to 25, but it won't have very good acceleration.
ZnsaneRyder
FL
Thanks Russ. 5 seconds really isn't a very long while, especially if used on a bicycle trailer, I don't want to take off too fast. 10 seconds or so would even be fine to get up to speed.
2or3wheels
Minneapolis Minnesota
do you have a thread with you trailer set up? im very intrested in motorized biking. i have the bike im going to use as my test runner. havent decided to go frame mounted rack style mounted or what you have trailor mounted.
ZnsaneRyder
FL
Sure
http://www.motoredbikes.com/showthread.php?t=12502
The first pics are simple, as it was new, then later on, I added ball bearings, more steel, and changed tires. I still have to upload more recent pics with it painted black with a new cargo rack on it now.
ZnsaneRyder
FL
Holy cow how long is your thread on that site about the trailer?
22 pages. :bannana:
It's just like a go-kart that attaches to the rear of the bicycle.
It hauls stuff too, BIG plus for a bike!
Now that's been done, I'd like to use my B&S engine to make a slower, simpler, and less expensive trailer.
I figure that if that engine can push a bicycle, then it also should be fine for the go-kart that the thread starter wants to build with this type engine.
