BradenM
Etre Et Durer.
I'd take the time to restore an engine like that. I'm getting an old villiers of a friend, lucky to do 1000rpm, and I'll be restoring that to factory specs.
Stick a long screwdriver down the sparkplug hole and measure the stroke. If it's 1.5", then it's a "5", which is good for 1- 1.5hp. If the stroke is 2", then it's a "6", which is in the 1.5- 2 hp range. These motors were built in (I think) the late 40's to late 50's.
Not real "performers", but interesting, none-the-less.
Or use a caliper.
Only if it's NOS (New Old Stock), and would have to find the right buyer. Check Ebay. There's still tons of them (used) out there.Are these old engines worth a lot of money?
If the rod throws hard enough it will punch a hole even threw cast iron.
Rods in these engines are not 'beefy' and will break just as easily as any other stock rod. My point is, there is little (if any) collateral damage.Then again if they are so beefy the rod wont be breaking anyway.
Yes, about 5 seconds.Sounds reasonable but It will take you a while to get there.
do you have a thread with you trailer set up? im very intrested in motorized biking. i have the bike im going to use as my test runner. havent decided to go frame mounted rack style mounted or what you have trailor mounted.
Holy cow how long is your thread on that site about the trailer?
