old B&S 3 hp engine
zakman
hey, i just found out last year that i love small engines, i was wondering how to take off the gov and hook of a throttle.
thanks
zakman
B&S
i have no idea but its old enough to have an oil bath...the logo on it is the diamond and black and white, so i dont know how old or what model number it is
oscaryu1
That's a Briggs 2HP. Most likely a common 60102 model. Oil bath are on all the 2HP's I know of.
3HP's use a more complex diaphram carburetor + much bigger fuel tank, as with a foam air filter.
zakman
is there anything i could do to make it preform better, and attaching parts for go kart making?
Affair_driven
BULL DETECTOR
Wolf Point, Montana
What size is shaft? 1/2 inch or 5/8 inch?
Appears to be a 5s (rated at 1.0 hp) or a 6s (rated at 1.5 hp).
May possibly be a model 8 (rated at 2.5 hp) but carb and blower housing is wrong.
What does id plate say?
oscaryu1
Oh whoops, my bad. Affair driven is correct. It's a 5s/6s model. Didn't notice the shroud type. Darn box!
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
As a teenager, I tried to press into use a B/S 5s on my minibike, and although it worked, I couldn't wait to get my less-old 6b back up and running (messed up magneto/coil). These things just weren't very powerful, and as a "kick-in-the-performance-groin" they were heavier than their more modern KoolBore counterparts. As stationary utility motors, they excelled.
I have two of them, and although I'll never use them in a project- I'll always keep them.
oscaryu1
They look so cute :)
The intake ports are TINY though, I'd love to see a "racing" 5s/6s. Now... where can I buy a CNC, mill, and lathe? :p
ZnsaneRyder
Crazy Guy on a Bicycle
FL
WOW, without the milk-crate, that engine in the picture looks EXACTLY like engine I just scored from an old edger at a yard sale!!! Air cover and everything looks just like it, and it gets oil in the air filter after running it for a while. The engine cover is SO rusty that I can not tell anything about it, but it runs and idles great!
How old are these? 20, or 30 years old? So how many HP? I see 1.0, 1.5, and 2.5HP mentioned, but does anyone know for sure? I'm not worried about it being too weak at all, as I'm putting it on a new bicycle trailer geared to go only 25mph, but it would be nice to have a clue of the HP.
Also, it appears to have a 5/8 shaft, so it should fit a clutch.
ZnsaneRyder
FL
Zakman, good luck with your engine, I'm sure you will put it to good use. If it's not powerful enough, there is a 2.5HP 79cc OHV engine at Harbor Freight tools that would do, but I would try to use your old engine first.
Anyone know how much HP these old B&S have?
Jerryburger
Admiral Annoy
Stick a long screwdriver down the sparkplug hole and measure the stroke. If it's 1.5", then it's a "5", which is good for 1- 1.5hp. If the stroke is 2", then it's a "6", which is in the 1.5- 2 hp range. These motors were built in (I think) the late 40's to late 50's.
Not real "performers", but interesting, none-the-less.
ZnsaneRyder
FL
The metal fan cover on mine doesn't have the same shape as these engines, it's more square at the top near the cylinder and round at the bottom. It's probably a variation of the 6S.
1HP-1.6HP should be enough for slow speeds right? I was figuring, for Zakman's go-kart, or my bike trailer, that 3600RPM at 20 or 25mph should be a proper gearing. Any input on this?
