New minibike build, and a few others..
jr dragster T
Cold place
Its machined from solid steel? If so its concidered Billet. Fusion welding doesnt get the same kind of penetration and heat as MIG. Tig it if you want but I'm willing to bet the welds will crack after a while. If your good at MIG it will turn out very nice. Theres a reason why all the couplings on crankshaft dyno's are MIG'd and not tig'd.
Raywelder
Not an Adm¡nistrator
Oh, I guess it is then, learned something new then. but its black, not shiny, the flange is though.
I can mig good so I may just do that now.
modelengineer
Lord of the noise
Sydney, Australia
Whether you do MIG or TIG it, if it's a critical part like a crankshaft then it should be heat treated afterwards to avoid these stress cracks that Tyler mentioned.
Raywelder
jr dragster T
Cold place
Ohh so Its like those uni fit hubs you buy and slip them together and weld. I thought it was just 2 peices butted together. You would probably be fine TIG welding that as most of the stress is taken up by the hub fit. However the HP of that engine just could cause weld fatigue. It happens all the time on the chasis of our race cars.
Raywelder
Yea, bought the hub at tsc, then had the machinist make it fit the flange and shaft.
The machinist put the flange a tad higher than the hub for the purpose of fusing it.
You can see the heat marks where I welded it to a hub before but goofed and had to cut it back off.
So I might heat treat it just in case.
Raywelder
Ah what the heck, I just noticed that speedo has a trip meter.
But wheres the butttton?!
Raywelder
Must have missed this pic.
how it mates up.
Its setting in there sideways at the moment though.
Raywelder
Well, I tig'd the top of it. About half of it perfect, the other side, has a bunch of pinholes in it from impurities.
But I ran four small mig beads on the other side of the flange just in case.
Raywelder
Flash, Sucks
Finger over flash
You can see about halfway it starts getting pourous, and doenst look as good cause I went back over a few.
But that one half came out really good.
for my first tig Project, I'm tickled.
