my mini chopper
It does look kinda wierd...There is about 1/8-1/4" travel... With it set right... There isn't alot of travel needed to actuate and clamp.
It does however works great...
This caliper has the actuator at the 6-12oclock positions... My other bike has a different caliper with the 6-9 o'clock positions...
Iron John
NA
It isn't the amount of travel that has me wondering. It is the angle of the arm. I thought starting perpendicular and moving away from that provides less mechanical advantage than starting at an angle and moving towards perpendicular. Like using a ratchet wrench - pulling towards a right angle gives you more oomph than pulling away from one.
Its angle it relative to the position of the adjusted position.
Its hard to describe... but more angle would mean more travel to get lock up and I dont have much room on the handle bar to get the leverage(from the hand lever)....
If I have understood this correctly.....
Iron John
NA
This is really hard to describe in words and so easy to show if we were standing there, bench racing with a beer. It's not the amount of travel, I am talking about the starting and ending angle.
Imagine you have a bolt in a vise and put a ratchet on it. You are facing the vise.
Now put the handle of the wrench parallel to the vise jaws and pull it towards you. You are starting perpendicular, and as you pull the angle gets less (more away from the baseline).
That is not the way you'd do it. You'd start with the handle of the ratchet angled back away from you so the angle increases towards the baseline as you pull on it. This gives you much more force delivered because leverage is working for you instead of against you.
If you drew a vector diagram, in the first case some of the effort is rotating the handle away from you so is not effectively available. In the second case almost all of your effort is doing what you want it to do.
Again, I am doing a terrible job of explaining but hopefully...and if not, what the heck.
Thank you John... Ill do some thinking on it....
Speaking of Brakes.......... I have a tale....of a KEY note....... Ironic....I think there was a man that once said.... Oh yes let me look back a few........
....... KEEP YOUR KEYS LOCKED DOWN. by any means necessary...
:oops:
AHHHHH yes.... No wiser words were ever spoken in such an adventure.....
You guys are probably saying....... NOT again... really.....
Yaaaa sooo... I have a kinda funny walk about me nowadays... cause when you dont remember to lock down the keys properly...... Youll have not alot of choice but.... TO FLINSTONE IT.......
Literally in this case... at about 60kph or so...
My pride... slightly taken aback... but duly noted as to the importance of such measures of safety and doing a good pretrip inspection......
NOt to sound like a wisea$$ or man..... but definatley not as a dumba$$ as it may seem......
Oh im fine and the bike aswell... the world is also fine and somewhat unaware of my misfortunes..... till this...
Iron John
NA
There are certain things in life that conspire against you.
One is an extension cord or air hose will always catch on something. They must. Except if you were falling off a cliff and needed the cord or hose to catch on something to save your life. Because then you'd die.
Another example is a key. You cannot get them out when you need them out. But they will happily disengage on their own just to mess you up.
It's dark matter.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
So 2 guys are in a small plane, The pilot tells the passenger they are gonna crash but there is only 1 Chute and it is Iffy at best. The passenger looks around and sees nothing but an extension cord and some papers in the plane. He tells the pilot... "You go ahead with the Iffy chute, I am taking that extension cord". The pilot says "why?" Passenger tells him "That Sumbish is bound to get caught up on something before I hit the ground!"
Well its been a few years since I have been to a big show to bring the bike out...
Yesterday I went to one of the big shows here in BC and in western N America.
Back a few years ago I went to this show, but they havent had a motorcycle showing since.(Post 88, mid page)
http://www.diygokarts.com/vb/showthread.php?t=5461&page=5
This year they were... I was definitely stoked..... Not may showed up here in the area I was, but there was bikes all over the area of the show.
Usually about 50k+ at least show up to this event, more every year.
I pretty much talked to about at least a couple of hundred people.... probably more ... always had a group..... And I always get perched next to an expensive bike..... Ahhh good times...
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That is cool. You got a group of people standing around checking out your Bike.
While the "expensive" bike... people probably just walked past and went "Yup there is another fancy motorcycle, I like red."
Oh ya happens all the time..... Girls like my bike, alot of ol' school(Older and younger) guys like my bike.... But most (we'll call bikers)....... dont. They like the big money bagger or Big bear chopper or what ever brand next to me.....However thier ladies are talking about my bike......
This next year I hope to get full papers and a legal title to get it insurance and a motorcycle licence, so Ill be driving it legally.....
It can get to a legal speed for low speed vehicle, so I might be qualified for that class, but its going to be a big long drawn out deal and money will be spent....maybe a exercise in futility....... But I want a bike that I want to ride......
Here on Roadkill they say the same.... At the 10 min mark, theyre going to the beach....
https://www.youtube.com/watch?v=rArpyMXT2ew&list=PL12C0C916CECEA3BC&index=52
Predataber
Myrtle Beach
Jackshafts arent always used for gear reduction purposes. In this case it is to make the drive go from the left hand side to the right as u cant just turn the engine around or u will do 30mph in reverse.
But you can flip the tire in most cases. I get it though, so nice to have the option to slide the final drive gear, perfectly inline and not have 40" of chain flapping in the breeze.
Well thanks buddy... I think...
Kind of an odd bump... Especially on a topic we've already talked about a few pages back.
Actually, initially I saw this on my phone.... but didnt realize that it was( from this new calculator I found on my win10...) 6 years, 11 months, 4 days..... or 2531 days ago that this was originally posted.......
Crikey.......... that was like the 5th post.......
Definitely a necropost award candidate.....
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That has got to be the necropost of the decade! Where is Helion with his "Zombie imoji"
Stranger2189
I'm starting my first project.
I have a briggs and Stratton 3hp engine from and old edger to start off with and a mini chopper frame. Need help figuring out the in between like throttle set up, brakes and engine mounting.
This is the frame style.
http://www.mefast.com/
If you start your own thread, you should get more help.
You WILL have more questions.
New Thread on top left of mini bike section,
https://www.youtube.com/watch?v=NNqVoDjiVY8
https://www.youtube.com/watch?v=z7X2_V60YK8
LOL:roflol:
Well once again thanks for the bump...
As you can see... There has been a few lately...
Go start your own thread...
