My First Kart: Nitrous + 358cc = PAIN #2
trails
dirtdemon...
arkansas
best thread on here...the last 20 minutes my jaw has been gaping at this project--completley blown away. i love the nos idea....my god this is a kart from hell....let me re-phrase. this kart is still in hell. ( i know 20 minutes sounds long to read 3 pages, but i couldnt help but stare at a few things..)
Ibnzmonkey
Keep Austin Weird
Austin Tx
UPDATES!
OK, i got the Tires in the mail a few days ago. I bolted the Bearing Hangers in and got the rear axle finally assembled.
The brakes were a bit tricky since i didnt have a welder to make a bracket for the capiler but i got a little bit creative.
And as it sits now.
almost done, i just need to make a floor pan and get the brake cable routed. i should be done with those today or tomorrow. hopefully it runs, i haven't even started the motor yet.
Ibnzmonkey
Keep Austin Weird
Austin Tx
Problem......fuk. OK so the front wheel bearings are 5/8ths and the axle on the spindle is some metric crap 16mm. My original solution, buy 16mm bearings....but the OD on all the 16mm bearings is too large to fit in the bearign cavity of the wheel itself. fuk. So i cut off the original 16mm axles and tommorrow im going to home depot to get 2 5/8th dia. bolts and get them welded in place. That way ill keep the original bearings and everything will fit right. Anyone care to weld for me?
Ibnzmonkey
Keep Austin Weird
Austin Tx
Ok so i started up the engine and it runs like a dream. A little black smoke but thats ok. It really thuds, you cant tell in the video too well but its loud and thumpy.
mmmm....358cc.
i just saw that i still had the chain hooked up to the clutch. and it was all lose and such. lol.
Ibnzmonkey
Keep Austin Weird
Austin Tx
So i got the front tires mounted, wasnt easy. but i got the 5/8ths axles welded on for me. $20 at sals muffler shop. Anyways, tomorrow ill have driving footage, well see how fast this thing goes.
still no brake cable or floor pan (im working on those)....lol.
jr dragster T
Cold place
Lol look's like the loctite on the nitrous injector didnt hold! Anyways awsome kart! Also is that 5/16 studs holding the caliper? If it is I hope they dont bend under hard braking.
Ibnzmonkey
Keep Austin Weird
Austin Tx
Its not that it didn't hold, i loosened it so i could do some trouble shooting work on the carb. (the injector was in the way) And yes, they're 5/16. I think they're going to bend since i have them out so far but if i bring the caliper and the disk closer to the mounting point on the chassis then i think ill be good. Plus, braking is for fags.
how long is your axle?
Its a 30"
ed1380
Banned
ATL, GA
nice engine.
id love me a frame like that. what are they called? shifter kart frames or what?
Ibnzmonkey
Keep Austin Weird
Austin Tx
Tires need air.
I know, i already filled them. 45 Psi like the manufacturer states.
Could you get a close up of the weld's the muffler shop did?
Ill do that tomorrow when the sun is up.
nice engine.
IDK, i just got on Ebay and searched for Kart Frames. And i came across this one for $100 shipped with steering assembly....yes...$100 shipped. what a steal. Heres another one i just found
