My first engine teardown/rebuild
r_chez_08
Should be in the shop...
Cornwall, UK
I did quite a bit this weekend. I was able to buy a hone like the one discussed earlier for $16, and I also bought some lapping compound. On Friday I also got a new set of rings for the piston. The ones that were in there previously were definitely the wrong kind, as they were too thick for the grooves and had gotten jammed in there. Whoever worked on it before me had no clue what rings to use.
On Saturday I started off by honing the bore. I must say that it came out quite nicely. I forgot to take a pic of what it looked like, but it looked like the pic that was posted earlier by someone.
I then lapped the valves. As this is also something that I have never done before, I was quite hesitant to do it, but it worked out well. The stick with a sucker on that you are supposed to use to lap the valves was out of stock, so I had to improvise with a toy gun sucker bullet. I pushed a chopstick into the end of it and it worked well.
I then pressure washed everything again, waited for all the parts to dry, lightly oiled everything again, and started putting the engine back together.
As you can see I used my head to put the piston in. (Joking. I just did that for you guys. And I didn't use my feet to take the pic :arf:). Instead I just use a flat piece of metal to compress the rings and push the piston in. It was pretty easy.
www.youtube.com/watch?v=J-HleLmV9vY
I was able to borrow a torque wrench from someone, so I started putting the engine back together. As you can see, I made sure the timing marks were all lined up. My gasket I made also seemed to work well. I put the flywheel back on and torqued it to spec. I then put some of the covers I had painted back on. It is looking pretty good compared to when I started.
I still have a few things to do:
  • Make gaskets for the valve cover and install
  • Paint the gas tank blue
  • Install tank and reinstall all linkages using pics I had taken
  • Wait for my carb to arrive and install
I might test the engine by taking the carb off my other engine, just to see if it works. I do still have spark, and my compression looks good.
Missed this post, looks great- valves look good too.
How did you get the block so clean?!?
Oh BTW double nutting works for me.
Thanks r_chez. I was surprised how easy it was to lap the valves. I guess you learn something new everyday.
I got the block clean by using a lot of degreaser and my pressure cleaner. I had to do it twice to get all the grease off. I also used a wire wheel in a few places.
I too, use the jam nut method.
Thanks Toystory. I used the double nut method to get them out. I was at first worried that they were somehow fused to the block or something, but they came out fine.
I didn't get to do much this weekend except make lots of gaskets. I unfortunately didn't take pics of those, so there is no eye candy today :D
I am going to be going t a machinist today to get a adaptor made for the carb. I have taken the head off so that he can do all the measurements and check threads etc.
I will keep you all updated.
Can you believe it!! I finally got my adaptor made and got it on sunday. So I get home and putthe head back on, and when it comes to mount the carb, I realise that the guy made the adaptor assuming that the carb goes on the wrong way round. This means that if I turn the carb the right way, it sits at even more of an angle than it used to. :mad2: :mad2: :mad2:
I thought I could maybe just flip the adaptor, but the screws are countersunk into the front. I have given it back to him, so hopefully he can just roll another one off the press seeing that all the work is done already. He has to make the exact same thing, but just countersink the other side.
I had to grind away a bit at the recoil cover to make it fit.
Here are some pics though. At least you get an idea of what it will look like
r_chez_08
Cornwall, UK
Aw man, sorry its taking so long!
I could have made you something up when I sent you the carb.
Hopefully it gets sorted easily enough,
To be fair on the guy, the pics that I gave him actually look the same as the adaptor he made for me (like in the pic). I did however show him which way the carb was supposed to go when I gave him the job, and told him that the picture was probably for some other carb. He obviously just forgot over the LONG time I had to wait.
Hopefully you guys can check back in a few days and not months:censored:
I also wanted to ask you guys about carb insulators. I know I need one, but I am not too sure which one to get.
  • The first 2 pics is one that I got from the junk yard (both sides) - can I use this?
  • The third pic is an image I lifted off the net - must I use this instead of the first one I found
  • The last pic is what the net calls a spacer - Can I use this if I need to
  • honda-gx110-gx120-gx140-gx160-gx200-carburettor-spacer-non-genuine-2930-p.jpg
fowler
Bullsbrook West Aus
the screws u used
are they taperd or are they standard head
is the spacer thick enough to flip and redo the reccess on the other side
the screws u used
The screws are tapered. It is unfortunately not thick enough to flip and recess again. What he is going to do is clamp a new piece of steel plate onto this one, mark out the holes again and just redrill, retap and recess. LOL. I feel like a poet
