Thanks Nodroz. I was just googling this, and most people tell you to double nut it like you say.
I guess I should have googled first
I did quite a bit this weekend. I was able to buy a hone like the one discussed earlier for $16, and I also bought some lapping compound. On Friday I also got a new set of rings for the piston. The ones that were in there previously were definitely the wrong kind, as they were too thick for the grooves and had gotten jammed in there. Whoever worked on it before me had no clue what rings to use.
On Saturday I started off by honing the bore. I must say that it came out quite nicely. I forgot to take a pic of what it looked like, but it looked like the pic that was posted earlier by someone.
I then lapped the valves. As this is also something that I have never done before, I was quite hesitant to do it, but it worked out well. The stick with a sucker on that you are supposed to use to lap the valves was out of stock, so I had to improvise with a toy gun sucker bullet. I pushed a chopstick into the end of it and it worked well.
I then pressure washed everything again, waited for all the parts to dry, lightly oiled everything again, and started putting the engine back together.
As you can see I used my head to put the piston in. (Joking. I just did that for you guys. And I didn't use my feet to take the pic :arf. Instead I just use a flat piece of metal to compress the rings and push the piston in. It was pretty easy.
www.youtube.com/watch?v=J-HleLmV9vY
I was able to borrow a torque wrench from someone, so I started putting the engine back together. As you can see, I made sure the timing marks were all lined up. My gasket I made also seemed to work well. I put the flywheel back on and torqued it to spec. I then put some of the covers I had painted back on. It is looking pretty good compared to when I started.
I still have a few things to do:
- Make gaskets for the valve cover and install
- Paint the gas tank blue
- Install tank and reinstall all linkages using pics I had taken
- Wait for my carb to arrive and install
I might test the engine by taking the carb off my other engine, just to see if it works. I do still have spark, and my compression looks good.
Missed this post, looks great- valves look good too.
How did you get the block so clean?!?
Oh BTW double nutting works for me.
I too, use the jam nut method.
Dude, we're on the edge of our seats here![]()
So, have you got that carby adapter done yet?
Oh, dang... How long is this one going to take?
the screws u used
are they taperd or are they standard head
is the spacer thick enough to flip and redo the reccess on the other side
