My first engine teardown/rebuild
fowler
Bullsbrook West Aus
I've gotta ask
What the hell is a carb insulator
The first two pics look like a spacer
The second pic is maybe a gasket but looks completely different
The last pic is a standard gasket
The last pic (isolators, etc) may be called a spacer, frankly I just think it's a gasket. Whatever isolator you use, just make sure it's compatible (think factory stock) with your carb.
I've gotta ask
The first two pics are of the same insulator, just showing both sides. I have no idea what it does, but it has grooves in the one side that correspond to grooves in the carb face that faces the engine (like in the pics below). I am not too sure if it is for air flow or what.
In the GX200 carb diagram I have posted, you can see the isolator, as well as the grooves in it.
I think I will use the isolator in the pic and see how it works out for me. If it is a problem, I will get the other one
I got my head and new adaptor back last night. I just have to reshape it a bit, but it looks pretty good. The catb still sits slightly at an angle, but it should work fine.
This weekend I will hopefully be able to get close to finishing this baby :wai:
Wait, you mean it took him 4 months to make the first one & 4 days to do it again :huh:
I seriously got on his case the last few days. I was texting and calling him each day asking when I would get it. He said all that he had to do was clamp the first one to the steel plate and mark out the holes and drill. He said it took 1/4 the time to do it compared to the last. I wanted to say that 1/4 would be 1 month, but I thought I had better shut my mouth
So I only got a little work done this weekend. It rained both days, and all I felt like doing was sitting on the couch with my wife watching movies. I am also starting to take the engine out of my Citi Golf 1.4i, so that I can send it off to get reconditioned. It had overheated a year or more back, and the damage is only now becoming more noticeable.
I did however get the carb adaptor, gaskets, insulator etc on the engine. I redid all the linkages because of the different carb I am using. I also got the valve lash set and the valve cover back on.
That is about it unfortunately all I did.
- Does the valve cover need to be airtight?
All I have to do now is get the tank on, tighten carb down, get an air filter (I will try get it started though without one).
Updates to follow
fowler
Bullsbrook West Aus
looking good
its great to see u finally have the thing almost together
as for the valve cover
quite the oppersite
it must be free to breath without restriction into the air box
but it must be sealed to the engine as to stop any dirt getting in
fowler
Bullsbrook West Aus
it should be part of the air box
if u are not using the origonal air box then u must install a small filter on the tube
anyhting that gets thought the rocker cover will be free to roam around in the top of engine and cause massive wear
the rocker breathers are the only breather for these engines so u gottta filter the air that flows though
r_chez_08
Should be in the shop...
Cornwall, UK
Love citi golfs :)
Get a cheap fuel filter and put it in the end of the breather if you have done away with the stock air box.
Paul- Are you planning on using the governor? I think you're going to have trouble with it. I see that you are missing the long thin spring that runs in concert with the long rod that goes to the carb, and the tension applied is pretty important!
Could you maybe indicate on one of my pics where the spring should go? I didn't even know that it was missing. I must break out my diagrams again from the manual and have a look as well.
Post #129, middle pic, long rod. There is a long, fine spring that wraps around that rod, and connects to the governor arm, and to that really small hole on the throttle arm on the carb.
I got these diagrams in the parts manual. I am assuming that you are referring to part number 16. I have to look at the carb again to find the small hole you are talking about. I also see that I am missing part 20. I just have a wire connecting those 2 regions. You can see this is my teardown pic I took. It is pic 3. The person before me was obviously running it bypassing the governor.
yep thats the spring (#16)
u should have removed the governer duirng disassembly
I know, but I thought it would be good to leave it as I am probably just going to sell the engine if I get it going. If I don't get all the springs working like they should, the way I have it connected now will just bypass it.
I might crack it open again to remove, but we will see.....
