My first engine teardown/rebuild
I did quite a bit this weekend. I was able to buy a hone like the one discussed earlier for $16, and I also bought some lapping compound. On Friday I also got a new set of rings for the piston. The ones that were in there previously were definitely the wrong kind, as they were too thick for the grooves and had gotten jammed in there. Whoever worked on it before me had no clue what rings to use.
On Saturday I started off by honing the bore. I must say that it came out quite nicely. I forgot to take a pic of what it looked like, but it looked like the pic that was posted earlier by someone.
I then lapped the valves. As this is also something that I have never done before, I was quite hesitant to do it, but it worked out well. The stick with a sucker on that you are supposed to use to lap the valves was out of stock, so I had to improvise with a toy gun sucker bullet. I pushed a chopstick into the end of it and it worked well.
I then pressure washed everything again, waited for all the parts to dry, lightly oiled everything again, and started putting the engine back together.
As you can see I used my head to put the piston in. (Joking. I just did that for you guys. And I didn't use my feet to take the pic :arf:). Instead I just use a flat piece of metal to compress the rings and push the piston in. It was pretty easy.
www.youtube.com/watch?v=J-HleLmV9vY
I was able to borrow a torque wrench from someone, so I started putting the engine back together. As you can see, I made sure the timing marks were all lined up. My gasket I made also seemed to work well. I put the flywheel back on and torqued it to spec. I then put some of the covers I had painted back on. It is looking pretty good compared to when I started.
I still have a few things to do:
  • Make gaskets for the valve cover and install
  • Paint the gas tank blue
  • Install tank and reinstall all linkages using pics I had taken
  • Wait for my carb to arrive and install
I might test the engine by taking the carb off my other engine, just to see if it works. I do still have spark, and my compression looks good.
Wait up! Double check your piston is in the right way. You probably noticed the big end is offset; check to see whether the offset is meant to be on the top or bottom like A or B in the pic. Did you take the piston off the conrod?
Other than that you're flying along; good work :thumbsup:
Thanks for the concern Fabroman. I put everything back together using pics that I had taken before I removed everything. I didn't take the piston of the conrod either. I thought that there was no need to do that, and I didn't want to have a headache with those little springs that hold everything in.
I also used the AGK website to double check that I was doing everything correctly. They have some really good pics that can guide a person. I also made sure that the arrow on my piston head was pointing down like it was when I removed it. It is not so easy to see in the pic, so I have circled it
Ok, I went back & had a look at some earlier pics &, yes, that's the way it came out. I did notice the arrow; I specifically looked for it.
It still concerns me though. Most small engine conrods I've seen are the opposite orientation to yours &, remember, just because you didn't detatch the conrod doesn't mean someone else hasn't.
Maybe do some triple checking to be sure; I'd hate for you to go through all this only to throw a rod.
Edit: I just found an exploded view &, aparrently, that's the way it's meant to be so, you're good to go
I was away over the weekend, so no work got done on the engine. Sorry guys. I did manage to paint the gas tank before I left though. The blue colour is a lighter shade tan what I wanted, but it still looks good
R_chez - I received the carb. Thanks again. It arrived here is great condition.
I will now be able to test the carb and see how well it is going to work
When I got home I though I would try slipping the new carb onto the 2 long bolts. Like I suspected it might happen, the flywheel cover gets in the way due to the offset holes on the carb for mounting. My original carb had the mounting holes level.
Has someone got any ideas of what I can do to get this carb all the way up against the engine? The one way I can think of would be to cut the flywheel cover where it is getting in the way.
Any other ideas? I also took a pic of the new and old carbs beside each other for comparison.
Would an adaptor plate work? I'm not sure how much room you have around the port. Failing that, what about a short manifold (which would also work like a tunnel ram on a car).
Basically, if the studs were in a different place would there be enongh room?
If the studs were on a level with each other, like the pic of my old carb, I think there would be enough room. I just don't want to really go to the expense of getting an adaptor, but maybe I am going to have to go that route. For me, cutting the cover would be easier, but I also don't really want to do that.
Something to think about: what's under the cover that the carby can foul on?
r_chez_08
Should be in the shop...
Cornwall, UK
Hey- that's my carby in SA!
Lol. Have you got some taps and drills, and some basic cutting tools
You could quite easily make an adapter like this
Get a block of aluminium or steel, or even plastic may work. I would reccomend aluminium for it's corrosion resistant properties.
Using some oil or marking fluid if you have it, put it on the face of the carb and press it up against the metal block.
Mark centres on the two mounting holes and the throttle bore hole.
Drill the mounting holes to 5mm and the throttle bore to .710" (18mm), or as close as you have in drill bits, then use a rat tail file to get the centre hole as close as you can to the carb throttle bore diameter. you can also shape to the port opening.
Tap the mounting holes to M6 and thread in the carb studs. Chop off any excess stud
Mark two mounting holes to bolt it to the engine, and drill them out to 6mm, and countersink. Using countersunk m6 bolts, you can bolt the adapter to the motor, then bolt the carb to the studs.
Done.
Done.
Thanks R_chez. I am going to have to read this a few times to try and visualise it, but I will probably try something like this.
EDIT: I get everything you say, but when I get to the quote below I start getting confused. What do you do with the 2 existing mounting studs? Do i need more bolts? Sory for the confusion. Could you maybe explain it a bit more. Thanks.
r_chez_08
Cornwall, UK
Have a look at this.
Yes you need two extra bolts to bolt the adapter to the engine. Then thread in the existing studs and use the studs to mount the carb.
Nodroz
Belgium (Europe)
Does anyone know if the 2 carb studs in the head are just screwed in. Can I unscrew them out of the head, or will I have to cut them off?
I have seen a video of somebody removing them.
Get 2 bolts on one 1 stud. Bolt them tight together and then you start "unbolting" the stud.
Not sure if you can do this on all engines though.
