My engine tuning, performance, and short rides.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I was surprised! It made fast forwarding through the boring talky part worth it, Hey the guys got good reflexes and Grace, he jumped right in like he was expecting that!
Jrgunn5150
Rudderless
IKR? It was pretty brilliant I thought.
Jrgunn5150
Rudderless
This .290 @104LSA has some grunt to it.
Now if this non hemi head fits and i add 1.3 ratio rockers , ShOOooott. .377 lift @ 104 LSA
Will be looking for TC donations to handle it.
I see that, it looked to have pulled the tires a bit. Maybe slow down and focus on tuning and you'll have a beast.
FreeRunner15
OMG!
It's ok sweety, grandma thinks you sing wonderfully and if Murican Idolls can't see the um... beauty (ack!) in you, then that's (uht...) their problem.
lol :) awwww. Thanks Gramma! <3
---------- Post added at 07:37 PM ---------- Previous post was at 07:35 PM ----------
i will. i have a very important thing i need to tune right now..fuel.
If i ran lean and the carburetor choke valve popped off on a 290 cam? i do NOT want to run lean on a .377
i've got a mikuni on the way. i hope 35lph(Liters per Hour of fuel) is enough.
---------- Post added at 08:27 PM ---------- Previous post was at 07:37 PM ----------
i was just informed by someone who knows his kart stuff that a non-hemi headWILL indeed fit.
THIS WILL BE AWESOME!
and the 1.1 rockers will give a .029 lift :)
Real talk, i really will need two wheel drive for this. this nothing-but-wheelspin is only going to hurt my acceleration. i really want to gear higher to balance things out but the store said they aren't machining sprockets right now(its what they sell).
---------- Post added at 08:32 PM ---------- Previous post was at 08:27 PM ----------
Oh and i have a theory about the belts shredding.... Just smoothe off the edged of the TC driver..duh. deceleration mainly causes belt stretch and high rpms is when the belt disintegrates against the sharp edges.
chancer
&#596; &#613; &#592; u &#596; &#477; &#633;
COMFORT, TEXAS
In the video you mentioned turning radius... Go with a Live axle and this issue will get worse.
But with a live axle, you can eliminate that silly Extension and put your engine in the center so the TC fits. A good chance to use your welding machine too.
Kids see what happens when you smoke way too much dope. Camshafts get to be so powerful they blow the choke butterflies off and engines run too lean. So please stay away from drugs cause bad things will happen to you're brain. :thumbsup:
[/COLOR]Oh and i have a theory about the belts shredding.... Just smoothe off the edged of the TC driver..duh. deceleration mainly causes belt stretch and high rpms is when the belt disintegrates against the sharp edges.
Sheer brilliance. I wonder why nobody thought of that before :sarcasm:
All i can say is that you have a really thick skin......
Poboy kartman
Senior Moments Member
White Settlement Texas
REALLY? Why would this surprise ANYBODY? Have you ever seen your dullest knife get any sharper without help?
DUDE!!!!! GET SOME HELP! You HAVE to be on drugs.....(nobody is as messed up as you naturally.....even tho yo parents is bro an sis....)
FreeRunner15
Well noone told me why belts break so i learned all by my self by watching my video and observation. Not so dull now.
i wonder if i put this bottle in po boys gas tank if he will notice a difference
---------- Post added at 12:24 PM ---------- Previous post was at 12:18 PM ----------
Hope you have forged internals and it doesnt turn into a glow plug. :D hahahahahaha. 30% 1quart. i wonder if itd be fine on a full tank of gas.
---------- Post added at 12:27 PM ---------- Previous post was at 12:24 PM ----------
i wonder if this 19cc head with 1.1 ratio rockers will have a noticeable increase in power.
Jrgunn5150
Rudderless
It just won't run, I tried it on a quad like ten year's ago when I had a whole fleet of RC's.
Racing fuel wont't make a difference will it?
It just allows you to do more stuff that will make a difference, like increase compression or advancing the ignition timing, right?
I'm betting he's not using it for fuel as in the traditional sense....
I think he's drinking it....
So watch out for a serious case of heart and ....."valve seat" burn.... Might want to remove you head first.... Get better flow that way....
Inverted rectal-cranial syndrome they call it....
FreeRunner15
19cc head with 1.1rockers
---------- Post added at 12:39 PM ---------- Previous post was at 12:36 PM ----------
with 30%nitromethane, 8% oil, 62% methanol ?
Jet.
---------- Post added at 12:43 PM ---------- Previous post was at 12:39 PM ----------
and who was it on here that ran 20% on their minibike then was going 30% that weekend to let his drunk buddies try to ride it?
Jrgunn5150
Rudderless
It's not racing fuel, it's nitromethane lol.
---------- Post added at 01:44 PM ---------- Previous post was at 01:43 PM ----------
Jet.
and who was it on here that ran 20% on their minibike then was going 30% that weekend to try and let his buddys ride it?
It didn't even start
FreeRunner15
30% nitrometh.
He's trying to save me from blowing myself up lol.
i know guysss i need to jet bigger for this or i will literally blow up the engine. i might try half an oz in the tank though.
