My engine tuning, performance, and short rides.
FreeRunner15
My to do list:
-get torque wrench
- remove flywheel
- grind BLOCK on intake side and crankshaft on exhaust side. i may need another look to confirm.
-install .290 grind
- insert 6 degree timing key
-re-install flywheel
- finish frame weld
- put everything back on
ugh. Bob poor me a whole glass will ya. i think its a bourbon type-a day.
FreeRunner15
Block AND crankshaft needed to be ground.
and check this out..
i'm sitting in the garage grinding the crank,right? and this lil booger slams into the window in front of me knocking its self clean out lol..:
It's flying around now It was just stunned for about 20 minutes.
Jrgunn5150
Rudderless
A. Your pics aren't working.
B. How did you get your's before I got mine? Mine is still sitting in California lol.
FreeRunner15
Wait 'til you get it. Those guys can't even spell right in the manual. Or on the e-start.
on the starter there is a "circuit protetor" next to a reset button. Like if you trip a breaker kind of button i guess.
---------- Post added at 05:53 PM ---------- Previous post was at 05:52 PM ----------
i think i'm ready to put the engine back together and start her up.
i wonder if it will be lopy. i kind of like lopy.
FreeRunner15
Well it's back together now. Just needs oil, fuel pump, and gas tank back on and ,vroom vroom, tearing off belts.
---------- Post added at 06:58 PM ---------- Previous post was at 06:57 PM ----------
Weird, although it wouldn't surprise me if people crank them way too long.
That makes sense i think.
FreeRunner15
lol, i made a run of the new cam and it has a HUGE difference in throttle response. quarter throttle blip and it barks.
the "lol" part is it freakin blew off the freakin choke butterfly!!
---------- Post added at 08:58 PM ---------- Previous post was at 08:56 PM ----------
to be honest i let i run lean. no fuel pump was connected. gravity feed sux.
---------- Post added at 09:20 PM ---------- Previous post was at 08:58 PM ----------
First test, First fire up of the .290cam and the choke valve pops off lol. proof in video too.
ran too lean and i knew when i was running lean and knew better than not to do that. but hey..at least it was the butterfly and not the head,right? lol .the cam is powerful but not THAT powerful.
https://www.youtube.com/watch?v=RiebHnMeMTI
So it sounds like you are already stuffing up your new engine. It also sounds like you didn't even try start it as a stock engine before you started stuffing it up
FreeRunner15
It's the 212, silly.
lol and you should know dang well by know if i had the equipment and parts i would GAB any day on that engine.
FreeRunner15
i really dont want to post this vid but it's all i've got right now.
Fuel Problem but it runs and drives good for a few seconds.
https://www.youtube.com/watch?v=CqxL2m9o7X0
i guess i just need to buy a $20 fuel pump.
---------- Post added at 11:05 AM ---------- Previous post was at 10:23 AM ----------
Also found a dual outlet fuel pump in case i ran a second carb for boost purposes. i probably wont ever need it cause the torque converter is so power-limited.
"Vanna....can I buy a clue?"
Jeeze...where to start?
Ahhhhhh...forget about it....this is simple....he got toast for brains.
SOOOO..LET'S REVIEW: NAW...The video tells the whole story...
FreeRunner...that video was EPIC! Keep them coming!
BTW: Replace the piece of plywood with a child safety seat....there are a million jokes out there...unfortunately....not all of them are funny....
And you are just sad....whatever you are using to destroy brain cells....STOP!
You started off with 1/2 anyway....ever wonder why your mom and dad had the same last name .....but were never married? ...HICK!
