mattlepperd
- Messages
- 81
- Reaction score
- 0
I was thinking about your turbo this morning...You need to speed up the exhaust gasses because you do not have enough volume. What if you were to build up the walls inside the exhaust side of the turbo with JB weld? Sort of the opposite of porting? shrinking the exhaust between motor and turbo in diameter speeds up the flow. Now you need to wrap that pipe between the turbo and the engine so it does not lose heat. Hot air flows faster.
I have turbo'd cars and such but the stuff I turbo usually has at least 383 cubic inches...I think you could get that to work (and by "work" I mean spool up and sound neat) but you might have to go on the noisy side of the 3600 redline to get there.
oh well time will tell us
