must see... stupid go kart !!!
lemegacool
got boost? :)
quebec canada
UPDATE!
here's what the carby assy will look like
need to fabricate two flanges to connect the turbo's outlet to the intake and to rig the oil pump/tank under the turbo... stay tuned :arf:
jr dragster T
Cold place
Nice filter and carb. Is that those 75 mm inlet like $20 air filters? If it is those things are junk for filtering air. Even on my dragster its more just to get rocks and gritty water from flying into my carb venturi off the tires.
lemegacool
got boost? :)
quebec canada
yep it's a 20$ filter... like you said it's more for keeping big objects out... and mostly for the look.. i nearly never ride the cart exept to go get the mail (400m ride)... lol
lemegacool
got boost? :)
quebec canada
UPDATE AND FAIL REPORT...
actually its the brake caliper that failed... the turbo is now oiled! the only thing left to do to actually try the new setup is to link the compressors outlet to the intake... and plug the gas line
here are some pic... you can see the snapped brake...*SIGH!* i now have to buy another caliper... i think i'll go hydraulic this time...
maximumbob
It's a 13g off of a 1g automatic eclipse/talon. For the record the 14b flows more than the t25 that came on 2g dsm's. The 13g was the smallest offered on a DSM hence most likely to spool on this engine. Good luck on the project.
Rotore
Teh SPIK
Caguas, Puerto Rico
for the record i said 14g not for 14b. either im not that familiar with mitsubishi turbines anyway so thanks for the correction.
mike75925
thinker and tinkerer
Alto, tx
you are going to have alot of atomized fuel in your intake runner. thank god the turbo uses air and brass/bronze for seals and bearings!
Scorch3
You should finish this, and tape the result. I kind of want to see what happens.
lemegacool
got boost? :)
quebec canada
lol this is what should probably happen: ok time to start it, *many pulls of starter later* wtF@\!@#$#$%$$ WHY WONT YOU START! lol
mattlepperd
Just keep wrenching on it. Looks like you are having a blast and learning a ton...thats what its all about.
lemegacool
got boost? :)
quebec canada
How did you keep the love-joy coupler on the clutch bolt?
simple... take the bolt, cut the head (that leaves you with a stud) then take a 1/2 drill bit and bore something like 3/8 deep into the coupling, tighten set screw and tack weld the stud to the coupling from the inside. that makes you a "bolt-coupling combol" lol
