Mini Trail Buggy Build
n1kogr
Mass
Got a little work done on the rear arms today. If anybody has the hf tube notcher you would know that it does not notch 3" tubing, so i built my own jig/notcher. It did not come out perfect as getting the notch to be perfectly center but it came out good enough for me. Not a crazy update but just a little something to look at as i play the waiting game and wait on parts to arrive.
mysteryboy28
Lansing, MI
looks like you've got a little bit of crab walkin' going on there (right tire will be trying to turn slightly to the right). neat concept, although i'm not sure how strong it's gonna be. very curious to see how it turns out...
trailing arms are a b!itch to design and get right. i think i'm gonna refuse to build them anymore, because swingarms work almost as good, and are SOOOOO much easier to make.
exenos
Project Nut
You've never tired any serious jumping with a swing arm then. IRS is a must if you plan on getting more a a foot or so of air. It helps immensely with the uneven landings.
n1kogr
Mass
Nothing is mounted yet and they are not done just put them there so everyone can get the idea. I am using some pretty thick walled steel so i think they should be very strong. I am going to beat the crap out of this thing when it is done so irs is a must!!!
fowler
Bullsbrook West Aus
That's why I'm going to use three link
The most simple most adjustable sort
But they are a bit heavy
Swing arms are not all that cracked up
A arms are proberbly the best in weight with travel but are also quite difficult to set up
n1kogr
Mass
Well i got a little more work done. I re did the trailing arms and cut down the pillow blocks to fit inside. I also mounted them up on the aluminum axle i got. It will also have a bearing in the center of the axle for more support.
This is what i plan to do for the side support just another arm coming off of it going to a heim inline with the jackshaft for adjustability
mysteryboy28
Lansing, MI
:smiley_omg: i love milk crates! they are so awesome for getting everything almost a foot off the floor. plus you can stack 'em. so cool...
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
Im digggin it soo far. Ive been saving your pics to my computer. lol i think im gonna tackle something similar to this over the summer depending on how yours turns out.
n1kogr
Mass
thanks guys for the engine i am basically cutting the atv frame up and keeping the middle part with the engine and oil tank as everything is there all the mounts ect. and it would just be alot easier to just weld it right up to the back of the buggy frame.
n1kogr
Mass
I fastened the bearings to the arms today. Two bolts and a grease zerk for each bearing. Should work great now i am at a stand still till i get my metal in, should hopefully have it this week.
mysteryboy28
Lansing, MI
i think everyone is wondering: how are you going to reinforce the trailing arms to prevent them from caving in towards the center? especially if you hit tree stumps and rocks and stuff with the tires? from the looks of your most recent pics it looks like your only support is a single bearing, which will just pivot left and right like a mo-fo.
i reinforced the bejesus out of mine, trying to factor in all possible laws of physical damage, including twisting, bending, and extreme other forces that are associated with off-road riding.
rwd4evr
delaware
i think it will want to camber in and twist the trailing arm too.
n1kogr
Mass
The arms are not done yet i am waiting on my steel. They will have another tube going through them like an x with a heim at the end to adjust the camber. I tried to explain in my previous pics with a small piece of pipe
