Possom Point
Ok I lied!!!!! I did another trial after I read yours and decided to go ahead
so same setup with non drilled muffler
temp was around 270-290 on the head
WITH drilled muffler was between 230-240 give or take So drilling that muffler made quite a bit of a difference, seemed to be a little bit more responsive with the throttle as well.
my numbers came from the upper left head bolt, hope that was a accurate spot
if not I can post both videos on YouTube later.
also I pulled plug again to check ….. see pic
Brownstain. Thank you for the tips. Had me stumped on what to do, never had an issue like this.
hopefully we can figure out why it’s running lean still……..
