Nnnoooooo!
Happine— yeah definitely feeding, clothing, housing. There’s always times where we can’t work on our hobby projects for various reasons, because they are exactly that, hobby projects. But you have a lot to look forward to!What’s more important you’re kids happiness or feeding, clothing, and housing them?
Post the ad where you got the .670" carb.Aright fellas, took it for a spin yesterday, ran pretty good, but seems to lag a little bit on acceleration and kinda bogs out almost as in it’s missing on the top end (wide open throttle). This carb came off eBay (DONT HATE ME) Says it’s a .670 race blueprint carb with a .074 main jet and a .024 low jet, buddy of mine said it looked like it was running HOT from the plug, I took the exhaust off and the valve did look hot as well. I am using the Arnold muffler you can buy at hardware store with 3/4” threads instead of the stock muffler.
MOTORHEADS!!! What do you think it could be????
Sorry bud, I think you got taken. That looks exactly like those ads with the .650" carbs, description is a little different.Here is the link from ebay
FOR PREDATOR 212cc .670 Race Printed CARBURETOR & Filter KIT KART Mini Bike | eBay
1 Carburetor. When installing adapter make sure that the two brass air passages are not obstructed. The adapter will mount in either position, but only one position will work properly. 3 X. 074 main jet.www.ebay.com
when I went back and looked, the .074 didn’t sound right, I ran a .041 before and basically flooded my engine on my 420 and switched back to the .040.
do you think a timing key would be beneficial for this motor? Or just put the stock carb with a jet kit in it? I didn’t want to go all out on this engine but I definitely don’t want to burn it up if it’s not done right.
Well that’s poop in the fish bowl….. but you’re prob right. It is eBay…. I drilled jet with a #60 drill bit. Should be .040 now. It ran much better on top end and felt faster, at least from acceleration, BUT the plug still looks lean, I don’t want to give up on the carb yet but like you said not sure exactly what I have here. With the carb, is there another thing I can check? The jet was DEFINITELY SMALL!!!!!Sorry bud, I think you got taken. That looks exactly like those ads with the .650" carbs, description is a little different.
If it was a TRUE .670" SA bored carb, they couldn't keep up with the demand for that price.
Here's what I run on mine. I ran it with the stock 224 (before i built it up) with governor at 5300 rpm, stock air box, header, 28* ignition timing, 9.3:1 CR, PVL flywheel, it ran and worked excellent with a .035" main jet. I'm still not sure what the low speed jet is, I know its more then stock (.016"-.018"), I would say it's a .022", but I have no reason to pull it out and check, whatever size it is jus works very good.
Predator/Clone Kart Racing "SuperJet" Carburetor .675 SA Legal w/Jet Kit USA NEW | eBay
We include the"SuperJet" tuners Kit of 6 main jets. 035. 036. 037. Carburetor is ready for your custom engine build. Will fit all Predator Hemi and non Hemi engines and Honda GX200, BSP yellow, Greyhound, Central Machinery, and equivalent 196cc 208cc 212cc 218cc type clone engines.www.ebay.com
I would jus use a 1/32" drill bit and open the stock main jet up to .031". This works well with stock low CR engines.
As for you ignition timing, a +4* - +6* key will work. I jus can't tell you what the stock timing is, they ALL differ.
Too much timing is jus as bad as too little. Too much puts too much pressure on the connecting rod, too little, adds heat and looses power.
Let's say the crank has 27* now, you add a +4, now it's 31*. Probly too much
Or, it's 18*, then add a +4 key, now it 22*. Theres a gain there, but not enough to do anything with.
Now if it was at 24* now and you add a +4* key, now it's 28* which will be dam near perfect for optimal ignition timing for a stock to mild build with a stock rod,
It's jus 1 of those things you have to check yourself, if you wanna know.
Jus like piston ring end gaps, piston to cylinder clearance, valve spring install height, etc, ect.
It still looks lean, to me too.Well that’s poop in the fish bowl….. but you’re prob right. It is eBay…. I drilled jet with a #60 drill bit. Should be .040 now. It ran much better on top end and felt faster, at least from acceleration, BUT the plug still looks lean, I don’t want to give up on the carb yet but like you said not sure exactly what I have here. With the carb, is there another thing I can check? The jet was DEFINITELY SMALL!!!!!
also roasted the pipe I checked witho temp gun and pipe was about 390-400 degrees. Seems hot to me
I’ll try this tmrw, I did hit the head with temp gun real quick want to say was 290 or so. But I’ll check again tmrw, good call on the muffler. Didn’t think about drilling the plug out!!!It still looks lean, to me too.
Check temp on head, right above the sparkplug hole. That's cylinder head temp, it'll tell more about the combustion chamber temps.
After a good 20-30 min ride, it should be around 225*-250*, while idling. It'll be higher, but slowly go down as it sits and idles, but still should show 225-250*.
Look inside that muffler. It came with a plug in the middle. That's more restricted then the stock muffler, and cause hi temps.
Drill the plug out, or jus use the stock muffler. Or any stock muffler, if you destroyed the stock 1.
