jr dragster T
I know what WOT means but whats WFO mean?
It should be normal right hand thread. Your going to need a impact wrench. And to pull the flywheel i used a thick steel plate with 3(maybe 4? depends on how many bolts the flywheel accepts) holes drilled in it.I then put the bolts through the plate and threaded them into where the recoil rope thing bolts onto the flywheel. The middle of the plate should butt up to the end of the crankshaft and when you tighten the bolts slowly it will pop the flywheel off the shaft. Oh, and whatever you do, don't hit the end of the crankshaft with a hammer...learned that the hard way...(smashed threads)
