I would just roughly set the highend mix for now (richen till she starts boggin without a load)and play with idle stuff once you have it in a driveable state and can get it warmed up.
I've got both needles about 1 turn wider than the initial setting recommendations, and it's boggy when you flip the throttle open, and the idle's iffy, no matter how far you turn the needle either way. At one time it was running with the hi needle completely closed, but maybe Tillys have completely separate low/high speed circuits. I REALLY want to use a Tilly on it.
It seems that I might have jumped the gun a bit saying it's done- still alot to to take care of. When I first got the motor, I started hunting down info and missing parts on it. One of things I did was order a starter for an SA2-440, reasoning (ASSuming) that since the SA2-290 and the SA2-340 were the same, why not? Well, the 440 is bigger. I was willing to put up with the rope start until I had to keep pulling and winding and...
As it turns out, the hub/drive of the starters are the same; just the housing and mounts are about an inch and a half larger in diameter. So, since I'm waiting on the right belt anyway, I figured I'd Assburger the larger starter onto the motor. If it works, it'll save me lots of trouble and a ton of money. Then I can attack the carb. I have another Tilly HD carb waiting in the wings, but what's the point. The carb is cleaned out (Hopefully) adjusted properly and the engine's in great shape.
Hey Russ- Believe it or not, this is a piston-port motor. I thought for sure it'd be reed-valve. I've seen the pistons from both the intake and exhaust side, and this motor looks like the day it's castings first cooled. (Besides getting dumped around a UPS truck until things got broke off or bent.)
