Yes, i will be using the original motor mounts, and that was one of the main reasons i cut out the engine, the other reason being that it would have been very hard to get out without cutting. Under normal circumstances i would make my own mounts, but we just moved and my shop is very un-organized and i dont even have a bench/vice to work with so making my own mounts would be very painful.
UPDATE
I cant do a whole lot since my angle grinder is dead, but i will be getting a new one hopefully sunday. Before my grinder died i was able to do a little more cutting, i completely took out the original motor mounts and added a few small braces to the frame. I also started to make a muffler at school.
I cut the original mufflers off the headers, and moved them around a bit. I think i'll cut the pipe on the right, and make a Y pipe right there for my muffler.
The engine mounts are cut out, and i added a brace across the bottom frame rail. I will add one more towards the front and at least one more on top.
I also put a few between the frame rails, im hoping to get 2-3 of these total per side.
