Kaptain Krunch
Pro Junk Collector
Go to Bottom of Page 2.
I do know about Heyhow.com and other sites, but i'd rather post my build here. Over there they are all about "rules" and "safety".
i put the grease fitting right where the tranny bolts onto the frame, this i might just go and pick up another mower from my friend and take the 820 transaxle off of that, this one is pretty much ****ed at this point...I could also put in my peerless 700, but i was thinking about selling that on heymow for like $75.
Edit: Welding the diff was fine, only burnt myself once and it looks good, i did get a little splatter that i need to grind off but it should be fine.
You could ebay the 700, you may get a little more than that.
I put my peerless 350 on there for 60 BIN and it sold within 2 days.
Although, The guy went and tore it up 2 months later and was nice enough to send a 'nice' little message about it.
IF I Were you I'd just do a go cart axle set up and use a Right angle gearbox. Will hold a lot better than any lawnmower transmission.
You could sell the 700 for at least enough for the gearbox.
I kind of like having different gears, and hate centrifugal clutches. So im not sure if the RAGB would really work out. If i did sell the 700 i'd probably put it into either some parts for my steering or just put it into my dirtbike.
Haha, Yea good point, I do too, But the mower transmissions fall apart eventually.
A RAGB with a TAV would Be awesome
so 4 years ago when you got the mower you were 7, and now you're 15. looks like someone failed math class and its not me
