Scatter shield?.....priceless!Governor Removed $0.00
Mikuni Fuel Pump $25
GX390 Carburetor $35
AGK Carburetor Adapter w/ Pulse Fitting $40
UNI Air Filter + Billet Adapter $35
Stage 1 Candy Cane Exhaust Header $28
I talk to my local kart shop today and alot of guys are running with these motor first thing they are doing is completely removing all the piece to it and are not running into any problem.
wait a minute you say you taped the fuel line together because it might backfire?? I dont see how a back fire affects the fuel line. And I know why your cart is just taking off when you release the choke. Right now your motor is wide open full throttle. Normaly when there is a governer the motor starts up on full throttle then when the engine is running the governer closes the carb to its idle postion. So start it up, turn off choke hold the carb closed aggainst the black idle screw and it will idle right down.
Whys that because he removed his governar. I talk to my local kart shop today and alot of guys are running with these motor first thing they are doing is completely removing all the piece to it and are not running into any problem.have any one heard of problems with these motors when removing the governar.
off... so I got my hammer and chisel. After a few hits, she slid right off
