Homemade gokart
andriksen
ok, thanx jerryassburger!:D
So if i get a smaller sprocket it will go faster, and I wont destroy the clutch, It's that right?
andriksen
go kart
hey!
Here is a new update on my go kart
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
Wow! Nice job! At this point you've got a couple of options....
You can run the kart with your present motor (lots of 50cc karts out there) until you get the $$ for the Clone and clutch (#35 chain). I'd make sure the air shroud is back on the motor, as it's work will be cut out for it.
Or, go for a Clone and clutch set-up and keep that rear sprocket.
Either way, you're Golden.
andriksen
haha! to day I got my go kart almost done!
I ran it and it's going pretty fast! And I got a golf gti seat for it!:D
Stay tuned for more pictures
Kaptain Krunch
Pro Junk Collector
vermont
Haha nice, but a gti seat may be a bit big and heavy, and with such a small engine mite not be the best idea. Have you looked into craigslist for an older dirtbike engine? i bought a suzuki dr 100 dirtbike for 50 bucks from a friend than ran fine, and thats on my cart right now, but i've seen some cheap bikes or quads on craigslist that would make awsome cart engines.
andriksen
yeah maby i should check out the craigslist. but ow tite should the chain be on my go kart
Buick455
got any pictures of it?
Florida
Pulled taut enough to where there is no slop, but loose enough that it doesn’t bind when you spin the axel. That’s how I always set them up.
?? Maybe I'm crazy but is that motor right way around ?? looks like its gonna go backwards when he starts it, lol
Kaptain Krunch
Pro Junk Collector
vermont
No its the right way, look at the pull start and you'll see.
Buick455
Florida
Thats what makes me think its backwards... If the recoil handle was twards the front then it would spin the engine in the right direction for the chain to push the Kart foward... but hey, I have been wrong before one more won't kill me, lol
Oh wait... Does it have a gear drive built into the motor that in turn reverses the output rotation? them pocket bikes are weird, lol
Kaptain Krunch
Pro Junk Collector
vermont
Haha your right, i didnt see that, i thought i saw the recoil facing forwards.
Qmavam
Hey
Here is a update on my homemade go kart.
Stay tuned
And please say if something looks dangerous or something like that.:
I'm concerned about the steering, First I don't think you want the wheels to turn as far as they do, if they got turned that far they would probably not come back to center by themselves.
Normally the steering wheel will come back to center position
by itself.
Here's a link from this site, might be helpful.
http://muller.net/mullermachine/docs/ackerman.html
Mike
Buick455
Florida
Hey
I have a question.
Why is my chain slipping/jumping off? is it to tight? or?
Could be a number of things, but the first things to look for (most common) are:
1. Sprocket Alignment -
Motor output sprocket to axel sprocket, check with a strait edge ruler of some sort.
2. Chain Tension -
Put the ruler back against both sprockets and push down on the chain, should be like 7/16" deflection
3. Wobbly Bits -
Check and see if the axel is slopping about when you give it gas, just put some blocks under it.
If its not one of those it might be the fact that your motor is pulling the chain from the underside of the sprocket instead of over the top and gravity isn’t doing you any favors... like below pics
