Take the stock muffler and cut off the header at the box. Drill a hole into the pipe at a convenient spot.... insert and weld it up...weld up a strong bracket to hold the weight of the stack...
No tips on the sticker, sorry.
Rust on an aluminum con rod? You sure?? Post some pics, depending on where the corrosion is, it may be unusable.
I reckon the journal areas have a bearing liner, and that is corroded......
