jr dragster T
i forgot to tighten the bolts on my kart seat before. we all make mistakes!
Better then forgetting to torque the rod bolts that's for sure!
You should add a note infront of the machine that says MAKE SURE ALL JAWS ARE TIGHT i forget stupid things like this all the time on stuff. i forgot to tighten the bolts on my kart seat before. we all make mistakes!
I have my own idiosyncrasies as well with machines. For example I always remember to wear safety glasses while drilling but forget when I go to grind something. You aren't alone.This was the first time this ever happened to me. The one lathe mistake I make often is I forget to remove the chuck key from the chuck before I turn it on. Since I run my machine in reverse most of the time so the cutting is on my side of the material, that means the key comes right at my head.
Just 5 years of your life and some hurt pride though right? Broken pinky, those heal up nicely I hear.Thank God for racing suits, helmets, 5pt harnesses, and a plethora of friends watching you make a fool of yourself, said friends mostly being fire/EMT types.
I absolutely love when I have the right tool for the job, makes projects much simpler.The milling process is complete. This was enjoyable to machine because the cutter was brand new right out of the package, so it chipped away at the mild steel without effort.
I included the high resolution picture because I find "grain" in steel in the raw or cut fascinating for some reason. I just thought it was a cool picture so I included it.
Got some work done today on the differential mount. I spent (wasted) a lot of time trying to triangulate the various oddly-placed mounting bolt holes in three dimensions however after I got a few of them done and correct I looked at the clock and this was eating up way to much time.
Well done on the machining, I was uncertain about the bearings just sitting in your honey comb block but now I see that it seems to work perfectly.
Your spindle assembly looks pretty beefy, especially with the spindle itself being newly machined shiny steel.
Till I go and try it and everything is all off. Wasting time all the while. More recently I have been going with the think it through once and do some rough math as I go. It seems to have been working better for me since.
Those bearings ever come? Do you have the controller, batteries, wires etc.. for driving it yet?
That steering column looks like more work than it might be worth. Might be worth finding a different column with better splines off of it.
Probably worry about making the thing move about first.
Your son getting excited yet?
I have no idea what any of the things u make in the pictures are for but it looks awesome. I love the progress shots of people machining things.
