WillMatrix
- Messages
- 251
- Reaction score
- 24
I’m going to order the sprocket or a brand new converter kit. I would feel bad but this is a great hobby and I got into it to fix it up
Kinda contradictory there, maybe?
Fix it up.
Buy a $10 4.5" angle grinder from Hazard Fraught and polish (grind) that rust off. You will be surprised and gratified at what that simple appliance can do.
Plus taking it apart, cleaning it, and reassembling it makes you learn the TAV pretty much inside and out.
"If it ain't broke..."
Exactly...I also remember reading somewhere him writing it was a Comet converter. Why waste such a good part? Wouldn't that be tragic? I would go out of my way to save it! I had one stuck on the engine off the Beast. I bent the sheave taking it apart. I straightened it out on the vice best I could and it worked great even with a small bend...but it must be clean...just give it a chance! Clean it up and drive it bruh!
Work for IT and IT will work for YOU!
I just noticed I had a few older pics of my TC in my phone.
Notice how the belt rides in the driven pulley? It is sitting on the very outside diameter and on the driver it is down deep inside. The belt looks tight but it isn't. It's a special belt for a 7 inch driven.
Wes
Notice the chain. It's snug but it does have just a bit of lash in it. Don't have it too tight. My main axle sprocket really needs replacing.
And last but not least this is the abortion that was on the kart when I got it so you see if someone can make that contraption work you can fix yours...and if I can make that hunk of junk back right then why ain't you done already?
My TC is missing a sprocket and that gold bushing for the belt to sit on. Can you tell me which belt you have? I’m going to try that. And how did you move the axle to tighten the chain a little. It looks like we have a similar set up. And I tried to find the exhaust gasket but the exhaust and muffler needs to be replaced and the OEM is only 12 dollars
NO! NO! NO! I already told you! You move the engine and the torque converter to tighten the chain! You don't move the axle! I looked at your pics, tell me something... where are you missing a sprocket at? The engine pulley spins the big pulley and the big pulley is turning the the jackshaft. On the other end of the jackshaft is a small sprocket. That sprocket drives the chain down to your big sprocket on your axle. I'm at work right now but when I get home I will see about making a video for you. You are going to have to really loosen up all your mount bolts and shove that engine back.
Did you clean those converters? You can buy a brass sleeve for it. Also make sure someone didn't put a 20 series driven on there as well. It happens. The driven is the big one. A 20 series is symmetrical. If the sheeves are symmetrical it won't ever work right. That thing just don't look right to me.
Check out go power sports. You can get gaskets from them
If you lived closer I'd just go get you and your kart and we could work on it and fix it.
Wes
There ya go, proper knowledge is key man. I'm trying to help you out. We wanna get that Murray Explorer running around again terrorizing the neighborhood.
Now you need to make up a good name for it.
---------- Post added at 07:35 PM ---------- Previous post was at 07:34 PM ----------
Don't forget, you wanna tighten that chain slide that engine back.
The way your belt sits in the back pully is different from mine. I will take more pics of it when I get home. Can you please tell me what you think may be wrong.. kind of getting me worried but I’m sure you’ll know the next step to getting it right
I believe I have a 20 series from the number on it
My cart is running (no brakes yet) great!! I think when the guy idled it down it lost some speed but it is running stable. First pull every time.
