Engine cuts out?
solomon
ca
This is a fuel issue not on oil sensor issue. 1 of 2 things
1 in tank fuel screen clogged
2 gas tank has bad ventilation (drill holes in cap)
And Thats It!
crappyballer
T-Tecumseh?
well if thats the problem i will be super excited. but the engine will stutter as well even if just at half throttle if your hitting bumps. its not as apparent because honestly who cruises half throttle for very long. it seems to happen whenever the engine is at a constant rpm.
crappyballer
T-Tecumseh?
well i drilled some holes in my cap today and that definitely did not solve my problem, so now its time to take apart the gas tank.
crappyballer
T-Tecumseh?
nope, i was gonna try everything else i could first seeing how you had **** luck cleaning yours. but yea, this week i'm gonna pull the carb off and the gas tank.
residentg
...why did I do that?
just for fun, check out your kill switch wires / connections / switch. see if you have a loose or bare wire, maybe a faulty switch...
crappyballer
T-Tecumseh?
kill switch isn't hooked up to anything, the retard who had the kart before me just connected the kill switch to the back of the governor linkage and nothing else :mad2: so i can hook that up this week at some point.
residentg
what about the ignition lead from the engine that it is supposed to be connected to - where is that? If it is exposed, it could be touching the engine, momentarily killing it.
crappyballer
T-Tecumseh?
the guy who had it before me just replaced the engine so he just bought the new engine slapped it on and called it a day. so the on/off switch on the side of the engine is what i'm using at the moment to turn it on/off. and im assuming the lead is just connected to the normal engine switch.
residentg
Make sure that there are no unaccounted for wires. Check to be sure that the spark plug cap is on securely as well. Can you post some pics?
crappyballer
T-Tecumseh?
no problem i will pop the cover off and post pics of everything. what exactly do you want pics of? so i post the most important ones.
Kaptain Krunch
Pro Junk Collector
vermont
just clean out the carb if there are no bare wires hanging (that was the first thing i checked), with these ****ty tecumseh carbs, dont blow it out with compressed air, just use carb cleaner. Tecumsehs are really ****ty in the first place, have you considered just replacing the engine?
crappyballer
T-Tecumseh?
i dont want to replace the engine given that it is so new and the kart body isn't worth putting anything nicer on. now i did find the lead for the kill switch and it wasn't wired to anything assuming thats my problem i'm excited. i pulled off the tank and took some pictures and im going to put it back together later today or tommorow.
residentg
start your engine and then touch that green wire to a good ground point on the engine and see if it kills it, if so, attach your remote kill switch wire to that green wire and be sure to tape it up real well.
since you have the tank off, put a fuel filter on the fuel line
crappyballer
T-Tecumseh?
yea i got a fuel filter on it now, for the kill switch i just got a screw and screwed it to the black square behind it. the black square is rubber so it is plenty insulated. i took the carb off and i wanted to watch the video one more time before i take it apart. and then i can reassemble everything and see if any of my labors were worth it.
residentg
that screw should hold the green wire to the black kill wire, but test it out first as I described above
crappyballer
T-Tecumseh?
yup i wired the kill switch to it. now i just need to bolt the pull start and gas tank on so i can see if it works. andi need to get that carb all cleaned up too and put back on
crappyballer
T-Tecumseh?
now if none of this fixes my problem, does anyone think a new carb would fix it? and if so what would be the most economical carb for replacement?
